b16b questions?
Old Mar 15, 2005 | 06:46 AM
importjunkie's Avatar
Default b16b questions?
Ok i have already purchased and installed a b16b in my 95 coupe.
I have a few questions though. The mounts i used are the ones that came on the b16b. The motor sits a little high in the engine bay and i get the feeling the mounts are wrong.
I know i need to use the 3g integra rear mount and drivers side mount but i was wondering what mounts the b16b would come with. I know it came out of an EK so does it use the same mounts the b16a2 uses for the ek. I wasn't sure b/c i know this is a gsr block and was wondering if it did come with the mounts i needed.
The engine still fits and i can close the hood although the engine seems kind of close to the hood. Am i going to run into any problems just running it like it is? I don't think the engine will contact the hood under normal driving conditions.
Also i use the integra type r throttle cable correct?
Old Mar 15, 2005 | 03:41 PM
EVIL Hx Coupe's Avatar
Default Re: b16b questions? (importjunkie)
The motor comes out of a 96-00 Civic so the mounts are for that particular car regardless of what block is using, so yeah, same as the 99-00 Si B16A2 mounts.
About it being high, every B18 I've seen in a EG has always looked like it sat kind of high. I know you have a B16, but it uses a 1.8block so it should sit at the same height as a B18.
Take some pics of the mounts and engine bay post them so can see what it looks like.
Old Mar 16, 2005 | 04:36 AM
Default Re: b16b questions? (EVIL Hx Coupe)
Yeah i figured. I called HMO where i got the motor from and he confirmed that it does use the same mounts as the 99-00 si.
If thats the case then i'm using the wrong mounts. I already ordered the integra mounts i need.
Thanks for the help though.
Old Mar 30, 2005 | 12:12 AM
greatwhiteshark's Avatar
You could also try shimming the engine down a few mm but putting washers on the mounting bolts.
phelpsj2
Feb 22, 2011 05:27 AM
v8killaz
13
May 24, 2010 09:14 PM
jcayo11
Acura TL, RL & ZDX
Mar 28, 2010 01:51 AM
red5FWD
Jun 3, 2008 07:29 AM
5150CIVIC
Dec 5, 2007 08:18 AM
