B16B into ek?
Old Sep 19, 2011 | 11:07 AM
Knuckles91's Avatar
Default B16B into ek?
would i need to relocate motor mounts?
Old Sep 20, 2011 | 07:27 AM
Knuckles91's Avatar
Default Re: B16B into ek?
okay, i see lots of ppl have looked, can i get a response? im still learning here. =]
Old Sep 20, 2011 | 07:59 AM
C2K_TB_TEC's Avatar
what motor did your car come with originally?
Old Sep 20, 2011 | 08:29 AM
ef9_lover's Avatar
if u got a jdm b16b srt8 from japan or like hmotor etc... and no one has touched it. it should drop into your ek fine. b16b came out of ek in japan.
only thing u might have to do is change fuel rail or get a longer fuel line.
Old Sep 20, 2011 | 08:35 AM
stageonedc2's Avatar
Bumpppppppppppp p
Old Sep 20, 2011 | 06:27 PM
hybridmiklo's Avatar
Don't listen to this retard. Go look up what you need. Such as the mounts,shift linkage, axles, tranny, ecu. This site has everything you need to know to do the swap.
Old Sep 21, 2011 | 10:41 AM
ef9_lover's Avatar
what the FCK u talking about bro^ he asking will a b16b fit he not asking what you need. im telling him if its still in orginal form it should drop in. bc i dont know about you but ive bought mutliple swap where it had da/dc side post// tbracket and i had to switch out bc those side post//bracket dont fit ek. dipshit! the b16b orginal side post and tbracket are ment for ek also stock ek d series motor mount fit b series.. so it will drop in
also i dnt know if you've ever got a motor from japan (you sound like a broke b!tch who cant afford one) the fuel rail is opposite bc its rhd and fuel filter on opposite side. so he would need a longer fuel line or usdm fuel rail
Old Sep 26, 2011 | 09:44 AM
Knuckles91's Avatar
Originally the car has a D16Y8.
1996 Honda civic EX Coupe.
Old Sep 26, 2011 | 09:47 AM
Knuckles91's Avatar
I dont need to know what i need. i already know i need ecu, harness, linkage, etc. i just need to know am i going to have to relocate the motor mounts or will the new one just bolt into place in the stock spot.
Old Sep 27, 2011 | 06:54 AM
ef9_lover's Avatar
stock d series mount will work on the b16b
Old Sep 27, 2011 | 08:25 AM
Sleepek24's Avatar
No just get b-series mounts and drop it in.
Old Sep 27, 2011 | 12:41 PM
ef9_lover's Avatar
http://hasport.com/store/index.php/m...-ek/ekstk.html
hasport doesnt sell b or d spefic mount they say there mount kit and say "fits d series and b seires". bc ek d series mount are the same as b series
imo keep ur oem d mounts. polly fill them up if u want to make them stronger
Old Sep 27, 2011 | 06:54 PM
Knuckles91's Avatar
thanks. does this mean i wouldnt need to change them for any b-series swap or just the b16b?
Old Sep 27, 2011 | 10:03 PM
Sleepek24's Avatar
If you get the new mounts you can use them with any b-series motor you can think of and they are way better then the pos stock d-series mounts you have in there now which are probably worm to **** anyway.
Last thing you need is to use the ones you have now and have to pull everything out just to change the mounts when you already had the motor out
DO IT ONCE, DO IT RIGHT!!!
Old Sep 29, 2011 | 02:45 PM
ef9_lover's Avatar
stock d series mount will work on any b series motor he puts in the car. i agree with u there hasport avid are worth the price^ but if he doesnt have the cash stock d will work jus as well for the time being. my boys been running his polly filled for 6monthish.
btw polly filling mount makes the mount strong again. i seen people get mounts completely torn to **** (where u can pull the center piece out) polly fill them had work perfect till they had money for hasport.
stock mount (which he has) plus $20 for a tube of polly filling vs $300 mounts
big difference
Old Oct 5, 2011 | 08:34 AM
Knuckles91's Avatar
no way! im doin my research so i can do it once! i don wanna finish my build and then have to go back and make everything "right" i wanna just do it and have fun. no BS. haha
dthug
Oct 24, 2010 05:57 PM
fogell
Sep 17, 2010 03:21 PM
SleepyTow
26
Jun 15, 2008 04:34 PM
Special-K-Coupe
Aug 3, 2005 02:11 PM
Punker1234
Mar 4, 2005 01:24 PM
