B16b clone...
I have an ls motor which over torques the crap outta my crx (bought car this way) I believe i've found the crank and rods I need make a b16b replica from eagle. Just have 2 questions about it
1-where are the piston squirter passages located? Need to know which b18c parts I need to make this last
2-will b18c rods mount to a b16a crank?
Was thinking about ls vtec, but am not going to try that till someone gets one that lasts...
They don't do blocks or pistons, since I'm currently on a b block, still need to know about what I need for those squirters. Figured I'd ask about the rod-crank interchange while I'm here trying to figure out what I may need so that I can do it right the first time
Please explain this, unless it's wheel spin. In most cases wheel spin is caused from people thinking clutch-dumping with a sintered-iron race clutch in a semi-stock NA motor is the way to drive fast. A clutch that can be slipped a bit, as well as altering throttle angle, will vastly help wheelspin.
As for your other questions... It would be cheaper to sell your LS motor and start with a B18C1 block. It has squirters, which will allow cast pistons. The other option is using the LS block with forged press-fit pistons (yes, they exist). LS+machining+squirters will cost more than either of those 2 options, and will have a stronger block or lighter pistons, respectively.
BTW Honda didn't make a "destroked ITR" motor because it was different or because they wanted to reduce low-end torque. They did it for 2 primary reasons: Japan has a vehicle TAX based on engine displacement, and the ITR already has a 1.8L engine. The CTR was the poor-asian's ITR in many respects, and they certainly didn't want to out-class the ITR with a Civic. Otherwise you'd likely have seen stock Honda City Type-R's imported that will beat a modded NSX Type-R.
just throw some bigger cams than what you need and an ederbrock im you will lose low end and gain top end it will be like driving a more powerful b16..or learn to drive...or get better tires....there no such thing as a too much torque lsvtec....even on a crx..there people here with built b20vtecs and they dont complain...
integranator
May 12, 2006 02:56 AM
