b16a1 stutter/boggs on acceleration
b16a1 in 90' crx.....hey when slight peddle pressure is added the car kinda glugs/stutters/coughs for a sec and i back of then back o nat its gone.. it comes and goes also... my tune up status is good and theres a new o2... any idea?... no check engine lights either.. thanks
i am having the same problem. tested TPS, fuel, spark, timing... nothing. at full throttle it is fine. wierd. it may be the o2 sensors. i am going to check mine and then try reversing the wires from each sensor. It is very frustrating because i can't go down the freeway without either gunning it or else slowing down.
Mine is kinda like that but mine isent slugish at all its like a small burst of energy on the highway. When i drive normal it does that but when i get on it its fine. I have no idea what so ever.
Well I am pre obd, running only one o2 sensor, which is brand new... Could this be my problem? Lacking a secondary o2, confusing the computer? or is it ok that I only have 1 because im pre obd?
let me know about what happens when you reverse wiring,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hollysovdi »</TD></TR><TR><TD CLASS="quote">It is very frustrating because i can't go down the freeway without either gunning it or else slowing down.
i hear you on not being able to keep it constant sometimes... sometimes i cant even tell if its doing it or not when crusing, slips in and out of stuttering.. this has to get fixed!!
</TD></TR></TABLE>i hear you on not being able to keep it constant sometimes... sometimes i cant even tell if its doing it or not when crusing, slips in and out of stuttering.. this has to get fixed!!
Unless my ecu only needs one o2 then yea, they must be sending the same signal, I guess i'll look into what to do about that, thanks...
any more help out there?
ftisthebest
Apr 11, 2016 08:37 PM
