B16a1 into 95 ex !!help!!
Old Nov 10, 2003 | 06:42 PM
1ntensiveVTECivic's Avatar
Default B16a1 into 95 ex !!help!!
Everything is getting power, but the injectors are not getting gas because of the dissy...can someone explain to me how to fix this problem meaning how to wire up the dissy or what not...any advice will be helpful
Old Nov 10, 2003 | 06:58 PM
iwhichisme's Avatar
Default Re: B16a1 into 95 ex !!help!! (1ntensiveVTECivic)
i can only think of maybe trying an b-series obd1 dizzy. Should bolt up. Also did you swap over the injectors from the d16, which are obd1 injectors. All i can really think of. good luck
Old Nov 12, 2003 | 11:27 AM
94CivSi's Avatar
Default Re: B16a1 into 95 ex !!help!! (iwhichisme)
which wire harness did you use???
Old Nov 13, 2003 | 07:47 AM
vtecb20coupe's Avatar
B A N N E D
you can try doing a search on here for a wiring diagram or just simply locate a obd b series distributor.
EfSedanLove
18
Jan 7, 2009 03:10 PM
slowassBubble
Oct 10, 2008 06:39 AM
handa
12
Oct 12, 2004 09:08 AM
meanEG
Apr 14, 2004 10:26 PM
