LSVTEC wiring harness does not fit injectors?
Here's a part of the setup for my LSVTEC:
-OBD-1 GSR wiring harness
-JDM 98 ITR injectors
For some reason, the fuel injector plugs won't fit the itr injectors because the injectors have grooves on the side that gets in the way. Am I using the wrong combinations of obd-2 injectors and obd-1 wiring harness or something? I've heard most D and B series injectors are similar. Any ideas? Thanks.
Re: LSVTEC wiring harness does not fit injectors? (handa)
try some d series injectors or something and see if they are made the same maybe it will make a difference. maybe u were sent the wrong injectors that would suck but good luck anyways.
Moderator
Re: LSVTEC wiring harness does not fit injectors? (pane93civhb)
don't try anything until you know what the problem is!!!
the problem is you have an OBD1 wireharness with OBD2 injectors.....get some OBD1 injectors and you'll be fine....
Modified by chad at 5:28 PM 10/11/2004
Re: LSVTEC wiring harness does not fit injectors? (chad)
handa says they got the obd1 wiring harness maybe he has the obd2 injectors .. that would make more sense
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pane93civhb »</TD></TR><TR><TD CLASS="quote">handa says they got the obd1 wiring harness maybe he has the obd2 injectors .. that would make more sense</TD></TR></TABLE>
Here is a pic of one of the injectors. I hope this will give an idea of which injectors they are.
JDM 98 ITR injectors anyone?
my car is obd1 and they look like the ones on the top right... if i remember correctly. both for my b18b and my sohc vtec zc (jdm **** man) lol... good luck again.
Solbros Owns Me
Re: (handa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa »</TD></TR><TR><TD CLASS="quote">So that means my injectors are obd-2 and that they won't work with my obd-1 gsr wire harness? Oh boy. </TD></TR></TABLE>
nope...you can either snag the OBD-2 injector clips off of a scrap wiring harness and SOLDER them onto your OBD1 harness...or get different injectors
Re: (Emerika)
Thanks for all the replies guys. It helped me alot. I'm thinking of shaving the grooves on the injectors to fit my obd-1 wiring harness (an alternate way), since that's the only thing that's blocking.
Anybody ever done this, or think it'll work?
Moderator
Re: (handa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa »</TD></TR><TR><TD CLASS="quote">Thanks for all the replies guys. It helped me alot. I'm thinking of shaving the grooves on the injectors to fit my obd-1 wiring harness (an alternate way), since that's the only thing that's blocking.
Anybody ever done this, or think it'll work?</TD></TR></TABLE>
yes....i have done it and it works
SIR2Hatch
02-27-2010 11:35 PM
hialeahzbg
07-27-2009 08:38 PM
