B16a Swap problems (Kinda long)
The Car is 1989 Civic Si, 253K miles. It had a good running D16A6 from an 88 CRX Si that i swapped in about 3 years ago b/c the old motors timing belt let loose. I bought a B16a from an Integra XSi w/ LSD and PWO ecu from a trustworthy mechanic near me (Im not sure where he ordered it from). I used Hasport mounts, linkage, axles, and harness. Before a picked it up from him, I had the timing belt, water pump, wires, cap, rotor, plugs, valves adjusted, and clutch replaced. I also replaced the fuel filter and radiator while I was at it. In addition I moved he battery to the back using a Steel Summit relocation box w/ and Optima battery and ran 0 guage welding wire up to a distribution block w/ `1 line to the starter and 1 line to the fuse box. I started the swap last November and procrastinated and Im finally trying to finish it. When putting the engine in, I had a hell of a time with the rear mount, so I decided to pull the intake manifold. I figured since I had the IM out, might as well replace it w/ a AEBS manifold and Hondata intake gasket. Also I didnt want to screw around with Meineke so I bought a Hasport header and got a 99-00 Si AEM CAI from Summit. I pretty much got everything together now but it wont start. Im unsure of some vacuum lines, but I think I finally got everything else right. I checked all the grounds and they seem good. I initially thought my ecu was bad so I got another ecu (It wasnt the ecu, it was a missing ground). My cel comes on for 2 sec when I turn the key to on, I hear the fuel pump come on, it cranks fine, but it wont start. I pulled the return off the fuel rail and I have gas there and I pulled a plug and it has spark. When I pulled the plug, it didnt smell like gas but Im getting injector pulse voltage at the plug. I tried some other troubleshooting stuff to no avail, can onyone think of anything Im missing that may be causing the car not to start. Thanks
b16aCivicEF
10
Jul 12, 2004 04:21 PM
