B16a/b17a1 ( b17 type r ) Frankenstein
Old Oct 28, 2025 | 08:00 AM
Noa.san21's Avatar
Default B16a/b17a1 ( b17 type r ) Frankenstein
Hello everyone, I am new to this forum a friend recommended me this so I thought of asking about a Frankenstein swap/build that I am doing to my gs 1991 Integra that I’ve obtained for 1k$.
The car came with a b17a1 block stock / b16a JDM head. Unfortunately the ex owner had spun a bearing, regardless of that I accepted the challenge to experience how to rebuild a b series ( first time ).
I’ve found and bought from CT a block b17a1 bore 81.5mm and came with civic type r pistons, rings, b17 rods and b17 crank. It was wrapped in a box, unopened still after 4 years.
I assembled everything and gave me a good reading on the oil light/gap. Crank looked great, block look like it had low miles etc
I am also reusing the b16a JDM head that the car came with ( b17a1 stock spun bearing ).
So my idea was to swap block only and maybe upgrade its pistons ( in this case civic type r/ Nippon racing pistons ).
I sent the head to get a rebuild and resurface and came back looking great ( it was great condition regardless ).
So I am obviously new to the da9 b series as well since I’ve owned an ef si and crx before stock and restored from my part.
My question is do I have to check the valve to piston cleareance? How do you do it ? Anyone recommends any other methods ? Trying to acknowledge myself with experienced ppl as well so I would appreciate an answer from anyone with this kind of acknowledgement. Is it necessary to check the space between valves and pistons with this set up? Or should I send it ?
GearheadzAuto
15
Jul 21, 2006 03:52 PM
psegs80
19
Mar 6, 2006 08:30 PM
turbodohcsi
Apr 14, 2005 01:02 PM
one slow eg5
Oct 28, 2004 08:56 PM
eddie1681
Apr 17, 2002 02:41 AM
