B16A 2nd Generation VS. B18C
Old Sep 25, 2001 | 07:04 AM
TypeRGhost's Avatar
New User
Default B16A 2nd Generation VS. B18C
97-00 GS-R (B18C) Engine
DOHC VTEC 4 Cylinder 16 Valve
• Transmission: Hydraulic
• Diplacement: 1797cc
• Compression Ratio: 10.6:1
• HP/Torque: 180hp@7600/129 lb-ft@6200
• Redline: 8200 rpm
• P72 OBD-1 or OBD-2 ECU equipped.
• Inquire within for LSD equipped trans
92-95 Si-R (B16A 2nd Generation)
• Diplacement: 1595cc
• Compression Ratio: 10.4:1
• HP/Torque: 170hp@7800/116 lb-ft@7300
• Redline: 8200 rpm
• P30 OBD-1 or OBD-2 ECU equipped.
1,000 dollars diff. your thoughts on what would be best for a 5G Civic.
Old Sep 25, 2001 | 07:54 AM
Kalokohan's Avatar
New User
Default Re: B16A 2nd Generation VS. B18C (TypeRGhost)
GSR= the most supported engine in the aftermarket. You can easily turn it to ITR specs. Then again, I am only speaking this because I have one in my 93 hatch.
GSR in a hatch = Power & Reliability.
Another big factor though is your budget. Money makes the world go round.
Old Sep 25, 2001 | 08:51 AM
sloppy_seconds's Avatar
Banned
Default Re: B16A 2nd Generation VS. B18C (Guardson3r3)
the GSR will have lots of torque compared to the B16A...but YOU decide, it's your $$$!
--justin
Old Sep 25, 2001 | 10:20 AM
MysteryWagon's Avatar
Default Re: B16A 2nd Generation VS. B18C (slowasscx)
more displacement in the B18c which equals more power, and more potential
Old Sep 25, 2001 | 10:36 AM
smp534's Avatar
New User
Default Re: B16A 2nd Generation VS. B18C (ShaggenWaggon)
remember.......USDM is smog legal..........JDM is not smog legal!!!
go B18c
really u should look into just the B16a3 for the DA integ......GOOD MOTOR!
Old Sep 26, 2001 | 10:11 AM
Slain's Avatar
Default Re: B16A 2nd Generation VS. B18C (smp534)
b16's 111 tq b18c's 128 tq i believe that in it self is worth the differene in $$$...Both are good motors just depends on how much u want to spend
Old Sep 26, 2001 | 11:26 AM
brad.'s Avatar
Default yep
i also agree with a GSR....well maybe that's because i already have a b16 in my EF
Well a b16 with Type-R internals is always good
[Modified by [626]JDM-b16a-EF9, 8:27 PM 9/26/2001]
Old Sep 26, 2001 | 11:29 AM
eg6ajk's Avatar
Default Re: B16A 2nd Generation VS. B18C (Slain)
b18c..trust me....have a mildly setup b16a n/a and drove in a b18c eg hatches.....the difference is defiantly there.....
spend the extra now and benefit later.....most people with b16a always learn that the 1.6l is good but the 1.8 was a much better choice...
if you can get a b18c with a y21 or ITR tranny, thats defiantly improvement....next would be some JDM ITR pistons, CTR/ITR cams, skunk2 manifold, re-chipped ecu, and some good JDM or DC JDM 4-1 header....well into 170whp mark and 130lbs of torque
with b16a you always be about 10-25whp and 15-25lbs of torque behind......
Old Sep 26, 2001 | 01:58 PM
Kamin's Avatar
Default Re: B16A 2nd Generation VS. B18C (eg6ajk)
actually it depends
if your goind NA get the GSR
if your gonna turbo get the b16 and possibly throw a b18 bottom end (if you wanna build engine)
that will lower compression to somwhere around 9:5:1 and youll be able to run a little more boost.
and whats this about JDM not being smog legal? and if it isnt HOW do you get it legal?
Old Sep 26, 2001 | 02:51 PM
Katman's Avatar
Hmm..
well I've experienced both of these engines......well, actually, a B17A not a B16, but you can make a B16A just as dope as a B17A with the right setup.
B16A has a high-end powerband.
B17A is a step-up from a B16A, more power, but not quite as much as a B18C.
B18C has better all over powerband.
I don't bash on any of these engines..they're all dohp in they're own ways.
I see it like this though...
what chassis do you have? If you have an integra or civic coupe or a 4 door....just go B18C...those are heavier chassis and need power to tug all the wieght - makes sense right?
If you own a hatchback....you have more of a dilemma on your hands since you have a lighter chassis to begin with. Either a B16A/B17/B18C is good in a hatchback. Of course you can make way good power with a B18C, but B16/17's are fun too. I actually miss my B17 engine 8(... it was a high compression (CTR pistons) - short gear (ITR gears w/4.785 fd) setup..and I loved it. I like my current setup now too..but I always reminisce about my original B17 love.. the top end power was o-soo tasty... but now I have power from 4000rpm onwards rather than around 5200rpm onwards...it's cool, I enjoy it, but there's just something about B16's and B17's that appeal to me more....I guess its just the top end powerband....
...don't even bring up LS or B20/VTEC .....I even can't stand those UNRELIABLE half *** VTEC setups. Those 50/50 vtec setups rank up in the lame zone along with those fawking wack *** rip off SPOOM wheels..
good luck with whatever you go wiff.
[Modified by Katman, 3:52 PM 9/26/2001]
Old Sep 26, 2001 | 07:42 PM
Night Kid's Avatar
New User
Default Re: B16A 2nd Generation VS. B18C (Katman)
i had the same problem as you...but i figured why not do it right the first time? b16 is a good engine but the 128 tq kinda appeals to me..considering i had a puny *** d15 piece of shizzit, wayyyy big difference
Old Sep 27, 2001 | 06:56 AM
Speedz's Avatar
Default Re: B16A 2nd Generation VS. B18C (civicnightracer)
Katman, is it possible to build a reliable LS/VTEC?
Old Sep 27, 2001 | 07:33 AM
Katman's Avatar
Default Re: B16A 2nd Generation VS. B18C (Speedz)
I'm sure there's a way to....but I wouldn't know cuz I don't care for unreliable half-*** vtec engine setups!
Papichulo1767
Feb 9, 2008 06:42 PM
wc
May 8, 2003 06:00 PM
FBPninetynineEM1
Dec 17, 2002 07:56 AM
JDMOption
Mar 7, 2002 10:29 PM
nucar4me
Sep 22, 2001 07:13 PM
