B16 sputter, code 9 Help!
Old Jun 7, 2002 | 04:10 AM
nsxmatt's Avatar
Default B16 sputter, code 9 Help!
B16 in a 88 crx, We just got the new int. shaft so we could put on the drivers side axle so we started it up and it started...barely. It sputters pretty bad and misses alot. Rev it up to like 3 grand an it kinda clears out but still has a miss. After a few seconds the CEL comes on, code 9. We replaced the cly sensor, checked the plug wires and firing order but still does the same thing!!! We went ahead and drove it around the block and it drives but it's underpowered.
Need help! we gotta figure this out, were sooooo close!
Old Jun 7, 2002 | 04:16 AM
Mr.FBR's Avatar
Default Re: B16 sputter, code 9 Help! (nsxmatt)
Did you check the timing?
Old Jun 7, 2002 | 05:03 AM
nsxmatt's Avatar
Default Re: B16 sputter, code 9 Help! (Mr.FBR)
as far as the distributor timing, it's ok. It's in the same position as my gsr.
Old Dec 22, 2003 | 04:10 PM
4potnick's Avatar
Did you ever find the answer to your problem? I am having the same problems.
Old Dec 22, 2003 | 06:53 PM
88crxvtec's Avatar
Default Re: B16 sputter, code 9 Help! (4potnick)
reversed cyl sensor wires caused it to retard timing as much as it could.
blasterman87
22
Sep 25, 2009 07:50 AM
reek
Jul 25, 2005 06:53 PM
teggytegteg
Feb 16, 2005 11:44 AM
done
Oct 8, 2002 03:37 PM
nsxmatt
Jun 17, 2002 02:18 PM
