B16 EG AC bracket issue
Old Dec 31, 2013 | 03:28 PM
eghatch07's Avatar
Default B16 EG AC bracket issue
Trying to use the under frame torque mount on my EG hatch with my B16. Bought a GSR AC bracket and things don't seem to want to work. Is there a difference between the GSR and B16 bracket? Can anyone tell me which bracket I need to use to clear up the issue? Thanks!
Old Dec 31, 2013 | 10:57 PM
goldsy's Avatar
Default Re: B16 EG AC bracket issue
What AC compressor are you using? If you swapped in a B series engine but are still using the D series compressor, you need the bracket/ torque mount from a 97-01 CR-V or a B series Del Sol.
Old Jan 1, 2014 | 06:34 PM
eghatch07's Avatar
Thanks for that info! I'm not trying to use AC, just using the bracket fir the added stability
Old Jan 2, 2014 | 05:35 AM
kyden's Avatar
bracket doesn't matter as long as it's from a b series. You need your stock torque mount. B series cars have a different frame rail shape.
Old Jan 4, 2014 | 11:50 PM
eghatch07's Avatar
I tried using the GSR ac bracket and there was about an inch of thread showing on the shaft and when I git things in place the ac bracket wouldn't bolt up to the block. I wish I could show pictures :/
Old Jan 11, 2014 | 01:02 PM
aavtec's Avatar
Are u using your stock mount? Tge integra one wont work.
Old Jan 20, 2014 | 05:53 PM
eghatch07's Avatar
I am using the frame mount from a GSR and the AC bracket from a CRV now. Haven't had time to try to bolt it up yet.
Old Jan 21, 2014 | 05:05 AM
kyden's Avatar
as i said, you need rubber parts from a civic, as the rails are different on b series cars.
Old Jan 21, 2014 | 08:47 PM
eghatch07's Avatar
Alright. That's no problem.
jeffhoe
May 22, 2013 05:03 PM
moco_machine
Sep 4, 2009 07:26 PM
jeffry6996
Northeast (Sales)
Feb 19, 2008 08:05 PM
Nicram
10
Feb 6, 2006 02:46 PM
nevin
Aug 13, 2003 01:14 PM
