B16 Compression
Old Jan 26, 2003 | 11:08 AM
rca90gsx's Avatar
Default B16 Compression
posted in Tech forum as well.... Wondering what a stock B16a (jdm first series) should put out when doing a compression test?
Thanks for your time,
Richie
Old Jan 26, 2003 | 12:01 PM
PhatOptimo's Avatar
Default Re: B16 Compression (rca90gsx)
1g B16a Compression #'s
Standard (new) is 185 psi
Low limit is 135 psi
Difference between cyls should not be above 28 psi
*NOTE* Use a fully charged battery when doing a compression test.
Old Jan 26, 2003 | 12:46 PM
rca90gsx's Avatar
Default Re: B16 Compression (Phat_Optimo)
Thanks very much for that. I'm used to the 4G63 engines... still learning on the hondas. This is a great forum for that.
Richie
Old Jan 26, 2003 | 05:06 PM
ALLmotorCRX's Avatar
Damn my b16 is hitting the 205 marks on every cylinder. Now i know why i use Mobil1 supersynthetic.
Old Jan 26, 2003 | 05:47 PM
PhatOptimo's Avatar
Default Re: B16 Compression (ALLmotorCRX)
Carbon build-up will cause high compression numbers.
Old Jan 26, 2003 | 10:22 PM
irev210's Avatar
185 is cold test right?
Old Jan 27, 2003 | 07:51 AM
PhatOptimo's Avatar
Default Re: B16 Compression (irev210)
No the engine should be warm (radiator fan come on) when doing a compression test. Also remove the 2-p connector (ignition coil primary lead) form distributor.
crxfreak1117
Oct 13, 2006 12:22 PM
davidcrx89
Jun 26, 2005 10:52 PM
Capt. Jimbo McSubipants
Feb 21, 2005 12:33 AM
mustbenu
Jan 23, 2004 12:56 PM
lothian110
Oct 28, 2003 09:24 PM
