B series civic header problem
I have a 1993 civic ex sedan with a gsr swap in it, and apparently the guys that did the swap over 3 years ago put an LS stock header in the car. it bolts up perfectly to the exhaust, but I discovered today that it was rubbing against the oil pan and actually rubbed a hole in it. I pulled the A pipe, grinded downt he weld that was rubbing and welded up the oil pan, but am thinking of getting a different header.
In a perfect world i wold be able to get a direct bolt in replacement that would clear the oil pan better....but, I dont know if there is such a thing.
What header will bolt up to my exhaust like an integra LS header , but NOT touch the oil pan like mine does now?
thanks!
thanks!
