Automatic EX vtec harness
Old Mar 28, 2004 | 09:06 AM
dat_flip's Avatar
Default Automatic EX vtec harness
I got a vtec harness off of an automatic 96-98 ex that i plan to use on my b-series vtec swap in an EK. I pretty much figured out which plugs I need and which plugs I don't need and which plugs i need to change out but I can find where the actual seconday o2 sensor is suppost to plug into. I found out where 3 wire go from the ECU side but i cant find where the sensor acutally plugs into. And are there going to be any other problems i am going to run into with using an auto harness
Old Mar 28, 2004 | 01:08 PM
ek99's Avatar
Default Re: Automatic EX vtec harness (dat_flip)
If i were you, i would just buy a 5spd harness. I did the same swap in my ek auto and just could not get the automatic harness to work. I even took it to some reputable shops and even they couldn't do it. They got it to run ok, but still couldn't get the vtec to work. So i just went out and got a 5spd harness and all my troubles were over.
DO_ITR_YoungD_19
Jul 1, 2012 04:18 PM
MiNDTRiP03
Sep 16, 2009 08:11 AM
ITR.#1446
Aug 30, 2005 06:14 PM
b20vtecEK
May 3, 2004 11:12 PM
dat_flip
Mar 28, 2004 07:35 AM
