arp head bolts
Old May 1, 2001 | 02:35 PM
jboostedhatch's Avatar
New User
Default arp head bolts
i have a b16a head on a ls block,
what ARP headbolts do i purchase? do they make b16a head bolts?
Old May 1, 2001 | 06:39 PM
stizzit's Avatar
Default Re: arp head bolts (jboostedhatch)
don't hold me to this, but im almost positive you need the ones for the head that you have. The vtec heads are a little bit taller, thats why.
Old May 1, 2001 | 07:18 PM
sgT's Avatar
sgT
Default Re: arp head bolts (stizzit)
vtec headbolts are shorter than ls headbolts.
Old May 2, 2001 | 12:52 PM
New User
Default Re: arp head bolts (sgT)
does that mean to use gsr arp bolts? didnt reall yanswer my question. which ones do i use, because arp doesnt make ones for the b16a., unless the gsr and the b16a are the same
Old May 2, 2001 | 01:00 PM
sgT's Avatar
sgT
b16a,b17a and b18c bolts are the same
What I would do is compare the length of the hole that the bolt goes through
in both cylinder heads. If there is more distance in the LS head then I would
use the ones made for a vtec. If they are the same then I would use LS.
What bolts are you using now? Or have you not finished assembling yet.
Old May 2, 2001 | 01:42 PM
New User
b16a
thanks i hope your right
Old May 2, 2001 | 09:56 PM
sgT's Avatar
sgT
If you are using b16a headbolts now, then get the head studs for a b16a/b18c. They will work the same.
cinder0159
Apr 16, 2011 07:10 PM
monkeyboy313@hotmail.com
21
Mar 29, 2007 06:19 AM
brian3676
Dec 14, 2005 05:45 PM
jdmhatch94
Aug 3, 2002 04:57 PM
B_CRUZ!
Apr 7, 2002 08:44 PM
