Are all d series shortblocks the same?
Old May 18, 2007 | 07:55 AM
dpine's Avatar
Default Are all d series shortblocks the same?
Are they all the same in aspect to installing a Sohc vtec head (mini-me)?
The reason I ask is because I was wondering if there is a difference between the sohc blocks and the dohc blocks (zc) like waterpumps, timing belts, head studs, ect. when doing a mini-me conversion between the 2 blocks.
This is what I want to do:
d16a (zc) stock shortblock + D16y8 head
thanks
Old May 18, 2007 | 10:03 AM
dpine's Avatar
Default Re: Are all d series shortblocks the same? (dpine)
bump
Old May 18, 2007 | 10:15 AM
2fast4u831's Avatar
I'm really 2slow
people still have single cams? blocks should be the same. I would check teeth on water pump and timing belt.
Old May 18, 2007 | 11:03 AM
eg6ajk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpine &raquo;</TD></TR><TR><TD CLASS="quote">Are they all the same in aspect to installing a Sohc vtec head (mini-me)?
thanks</TD></TR></TABLE>
zc dohc block is slightly different, and will not allow bolt on for SOHC head without modifing the block and the head!
Old May 18, 2007 | 02:43 PM
boosted2182's Avatar
d16a6 and z6 blocks are the same if you want to put a y8 head on use the crx si d16a6.
hailchristian
Jan 13, 2010 09:50 AM
icanbrkurhrt
Jun 18, 2009 05:59 AM
duefuss
Jan 24, 2008 09:12 PM
CivicRaping
Sep 25, 2005 10:50 PM
sscrx
May 18, 2005 11:26 AM
