Adding a knock sensor to Y7 harness where does the ground go?
Old May 31, 2007 | 08:03 PM
hondakevin21's Avatar
Default Adding a knock sensor to Y7 harness where does the ground go?
I'm doing a gsr swap, and i'm stuck with using a D16y7 harness. I've got the vtec wiring all done and i'm working on the knock sensor wiring, I know where the sensor plugs into the ecu but where does the ground for the sensor go to?
Old Jun 1, 2007 | 06:00 AM
EE_Chris's Avatar
Default Re: Adding a knock sensor to Y7 harness where does the ground go? (hondakevin21)
It's a 1-wire sensor. The block is the ground.
illios
Jun 3, 2010 07:18 AM
mustninty20
Dec 19, 2008 03:36 PM
NoVALude
Apr 16, 2006 07:00 PM
lsvtec2000SI
Mar 14, 2005 12:32 PM
CrazyHB
Aug 30, 2004 12:15 PM
