ac in a b20 hatch
Old Apr 6, 2002 | 05:05 PM
drifter's Avatar
Default ac in a b20 hatch
will ac fit in a 93 hatch with a crvtec. Do i have to get different mounting brackets. What ac should i use. Belts?
Old Apr 6, 2002 | 06:31 PM
#417R's Avatar
Default Re: ac in a b20 hatch (drifter)
Yes it will fit. You can use the A/c from your Civic. Not sure on the belt size right off hand. youll have to measure it. I used the bracket off the civic to mount the compressor to the block. Good luck.
Old Apr 6, 2002 | 07:45 PM
drifter's Avatar
Default Re: ac in a b20 hatch (b20zkid)
thanks for the reassuring info
Old Apr 7, 2002 | 06:19 AM
rolow's Avatar
I am using a civic belt " Dayco 5040310 "
and the bracket is a b seires
Old Apr 7, 2002 | 10:02 AM
drifter's Avatar
Default Re: ac in a b20 hatch (rolow)
so both the b series and civic bracket work? thanks
danielblushtein
May 18, 2010 08:01 AM
danielblushtein
May 4, 2009 10:30 AM
civic25493
Jan 5, 2007 10:05 PM
wizzards581
Mar 30, 2004 05:55 PM
Charlie Moua
Oct 1, 2002 08:39 PM
