95 hatch b20 swap issues
95 dx hatch with a 2000 jdm b20b ls tranny
so here's my list of problems i need help with, if anyone has some input that'd be awesome!
-spedometer doesn't work, no CEL.....yet, the wires are in good shape and everything is connected
-lower radiator hose takes forever to heat up, I wired my radiator fan to a switch, but i'm thinking maybe it's my thermostat. the hose heats up but not nearly as fast or as hot as it should
-really hard to get it in and out of gear, maybe its my shift linkage, but it seems really stiff like it doesnt want to go into gear at all
-clutch pedal feels funny (not related to the swap, i know!) feels like maybe its the master cylinder, I already replaced my slave cylinder when that went out a couple months back, but there's no fluid leaking for under the pedal so i'm not 100% on that
Speedometer an odometer worked fine, I changed out my flywheel and it stopped. The tach still works though. The radiator fan didn't work, I trouble shooted the problem and it was some ground wire that went through the fuse box under the hood to under the dash. So to save myself the headache I just wiring it to a switch do the fan turns on automatically when the battery is on
Manolo
Jul 31, 2007 12:27 AM
