5th gear grind
Old Mar 22, 2003 | 11:10 AM
NorthernXposure's Avatar
Default 5th gear grind
when shifting from 4th to 5th at highway speeds i get a bit of a grind when going into gear.. any ideas what the problem could be? worn synchro? fluid not topped off?
Old Mar 22, 2003 | 07:43 PM
squirrel's Avatar
Default Re: 5th gear grind (NorthernXposure)
I've heard of some people with short shifters having that problem. Do you have one? If not, my best bet is a worn synchro
Old Mar 22, 2003 | 08:06 PM
97hb's Avatar
Mine does the same. I just let the rpms die a little before putting into 5th.
Old Mar 23, 2003 | 11:13 AM
iwhichisme's Avatar
Check your tranny fluid. If it is lower than what is should be, that is likely the problem. Ive had that happen, and for some reason the fifth gear gets fluid last and if there is not enough it will grind. THis may or may not solve the problem.
Old Mar 23, 2003 | 03:28 PM
TIRENECK's Avatar
Default Re: 5th gear grind (iwhichisme)
can you swap the synchros of a 93 LS tranny to a B16a tranny? i heard it was possible, dAM the b16a trannys, they go out quick.
Old Mar 23, 2003 | 08:57 PM
COMplex.'s Avatar
i heard royal purple is a good fix-it for this problem.. someone correct me if i'm wrong.
Old Mar 24, 2003 | 06:32 AM
KENLUDE97's Avatar
Well if this is on the h22, They are known to have a bad syncro on 5th gear. The best thing to do is change out the Fluid to "GM syncromesh" It is $9 per quart. I had the grind on my 5th gen Lude and as soon as i added the oil the shifting was better and after 500 miles the grind was GONE!!! i can not make it grind?!! I REALLY reccomend the oil...
Old Mar 24, 2003 | 10:39 AM
COMplex.'s Avatar
Default Re: 5th gear grind (KENLUDE97)
thanks for the info! i'll have to try it too.
Old Mar 24, 2003 | 10:41 AM
KENLUDE97's Avatar
Default Re: 5th gear grind (j.fuggi)
Glad that i could help. Keep us posted.
Old Mar 24, 2003 | 11:17 AM
Kittenman's Avatar
i heard that because 5th gear is the farthest away, it receives less oil then all the other gears, so, you might as well just try changing the oil and filling it up til it starts spilling out.
indtegra
Nov 5, 2007 07:22 AM
bboyfreeze
Mar 26, 2007 06:41 AM
2.3vtec
Sep 7, 2005 11:03 AM
ragerized
Jul 11, 2004 03:53 PM
John
Feb 12, 2002 12:16 PM
