5 wire to 4 wire o2 conversion...
ok, i got the the re-pinning down, and i was also told i couldnt use the stock vx o2 sensor itself. so i went to autozone today and bought a four wire o2 made for a teg, but its a universal peice. so my question is, on my connector that goes directly to the o2 what color wires do i peice on to the universal four wire harness? the colors on the stock harness are....
red
white
black
orange
yellow
any help is appreciated. thanks.
red
white
black
orange
yellow
VX WHT - 4 Wire WHT
VX YEL - 4 Wire GRN
VX ORG - 4 Wire BLK
The other BLK needs a 12V+ ECU switched source. It can be tapped into nearly any YEL/BLK wire under the hood. Due to it's location it's easiest to tap into any YEL/BLK wires of the injectors or the IACV.
VX YEL - 4 Wire GRN
VX ORG - 4 Wire BLK
the universal o2 i bought is like this :
black wire - o2 signal sender
white wires (2 of them) - heater wires
gray wire - ground
so which vx wires do what is basically what im asking...
gray wire - ground
I've always used OEM 4 Wire O2 sensors so I'm used to their color coding. This would be the wiring to the color coding for your universal O2:
VX WHT - 4 Wire BLK
VX YEL - 4 Wire GRY
VX ORG - 4 Wire WHT
The other WHT needs a 12V+ ECU switched source. It can be tapped into nearly any YEL/BLK wire under the hood. Due to it's location it's easiest to tap into any YEL/BLK wires of the injectors or the IACV.
VX WHT - 4 Wire BLK
VX YEL - 4 Wire GRY
VX ORG - 4 Wire WHT
you cannot buy an aftermarket 5 wire 02 sensor it is not available!!! Also the aftermarket o2's suck! you should never try and use a but connector on those wires you will run into problems...and there is no way to convert a 5 wire to a 4 wire...you pretty much have to take out a loan! and buy one from the dealer $500 plus...i do have a 5 wire available used the price is $150...w/ a 6 month warranty
From: hittin corners so hard you can taste my rims..
did you ever get anywhere with this? what ECU are you running now that your goign 4 wire O2?
ive trying desperatly.. but a P28 in my car runs liek ***..
https://honda-tech.com/zero...47560
slammedz6ef
Feb 15, 2008 07:46 AM
Houston Hatchback
Apr 23, 2003 05:17 PM
KevronsEG
Mar 31, 2003 10:11 AM
