3 sensor on the black a 90 LS block
Old Aug 5, 2003 | 07:37 AM
ProJectCvic's Avatar
Default 3 sensor on the black a 90 LS block
i am getting conflicking answer so i post a new one. i have these 3 sensor on the back of my b18a block. here is a couple of pic of it.
i think # 2 is low oil pressure. but i am not sure what the others are. Any help is greatly appreciated. Thanks in advance
Old Aug 5, 2003 | 07:50 AM
Default Re: 3 sensor on the black a 90 LS block (ProJectCvic)
#2 is low oil pressure
#1 is engine coolant temp
#3 ????
Am i right?
Old Aug 5, 2003 | 07:52 AM
syndicate43's Avatar
yeah you are right but I have no idea what that third one is either
Old Aug 5, 2003 | 09:02 AM
Turbogixxer's Avatar
Default Re: 3 sensor on the black a 90 LS block (syndicate43)
check your another post, your questions are anwsered
Old Aug 5, 2003 | 08:39 PM
idontcare's Avatar
Default Re: 3 sensor on the black a 90 LS block (turbogixxer)
#3 is block thermosensor. it activates ur radiator fans
Old Aug 5, 2003 | 09:40 PM
Default Re: 3 sensor on the black a 90 LS block (idontcare)
if i am understanding you guys correctly....the dx themosenor plug is orginally on the themostate, on the b18a motor...it is on the block. How would i rewire it? the wire color are different. Thanks for all of you that reply.
Old Aug 5, 2003 | 09:45 PM
it does not matter what wire goes in what position on the ECT. All the ECT sensor does is gives the fan ground at a certain degree. that it.
Charlie Moua
Mar 10, 2010 02:36 PM
PM-Performance
Dec 8, 2003 10:29 AM
IH82LOSE
Oct 3, 2003 01:54 PM
RuffRhyno
Nov 22, 2002 03:21 PM
Brian_92GSR
Mar 27, 2002 09:17 PM
