134 hp is this right?
Old Dec 13, 2002 | 06:57 PM
Chiclets's Avatar
Default 134 hp is this right?
I have a b16a in my 93 hatch and I put it on the dyno jet and I only got 134 hp is this about right. I have i/h/e and aluminum crank pulley and flywheel ( It was orginally on an automatic) what do you guys think
Old Dec 13, 2002 | 08:01 PM
DaNish's Avatar
Default Re: 134 hp is this right? (bluedemon)
sounds a little low to me but maybe im wrong...i've never dyno'd a basically stock b16 but i thought with your mods it would put out around 140WHP...maybe you need a tune up or something
Old Dec 13, 2002 | 08:08 PM
IM ALL BOB's Avatar
so your saying the b16 you have in your car was from a automatic SIR/ ferio civic? if so the automatic cams are usually less aggresive than the manual engine cams.. therefore you are making good power but you may consider changing the cams for a more ones with more lift and duration
Old Dec 13, 2002 | 08:17 PM
Chiclets's Avatar
Default Re: 134 hp is this right? (IM ALL BOB)
yes the b16 was automatic from japan and maybe the reason why power was low is because when I took it in to the shop I had it retarder neg 4deg let me know if this could be it
Old Dec 13, 2002 | 09:06 PM
DaNish's Avatar
could be
Old Dec 13, 2002 | 10:07 PM
CRX_VTEC's Avatar
Default Re: 134 hp is this right? (X DaNish X)
automatics had the weakest cams as well.. dont forget about the difference in ECU.
Old Dec 13, 2002 | 10:32 PM
Chiclets's Avatar
Default Re: 134 hp is this right? (CRX_VTEC)
what about the ecu?
Chiclets's Avatar
I don't have an automatic ecu
K7-1Ktrevor
Jun 24, 2012 09:14 AM
CarAudiophile
29
May 11, 2005 11:32 PM
civicb16eg
28
Mar 14, 2005 01:17 PM
WAFFLES
24
Jan 12, 2004 09:11 AM
Timmayeg
May 6, 2003 04:54 AM
