**Official H2B Discussion thread **
Old 07-20-2013, 06:06 AM
  #19551
HiProfile's Avatar
Default Re: **Official H2B Discussion thread **
Originally Posted by c.ridgell
This could be a general question however specific to a H2B setup and the H2B community has always been more than willing to provide helpful information… I start the engine, let the car idle and within five minutes coolant begins to drip from the bottom of the radiator. Temperature gauge on the dash reads cool. Radiator fan kicks on and shortly after coolant starts to backup in the overflow tank before spraying out of the top. I have replaced the thermostat, no success. What other components should I check? Water pump? Radiator and cap? This is my first build and any information would be appreciated. Thanks in advance.
Sounds like the coolant into the overflow is working as it should. When it hits operating temp, it is probably also at operating PRESSURE. Meaning the cap will bleed off overflow to keep it at ~16psi, otherwise pressure would keep rising. The leak below sounds like a minor crack or your radiator's petcock o-ring is shot.
Old 07-20-2013, 09:55 AM
  #19552
DrCRX's Avatar
If any one can get in touch with libertariat, Please tell him to get in touch with us. We have pm'ed him.
Old 07-22-2013, 06:17 PM
  #19553
Ek Forever y0!
Libertariat's Avatar
H2B oil pan sold.
Thanks, Eddie! Nice meeting you.
Going to make changing my oil this week about $20 cheaper, though
Old 07-24-2013, 04:07 PM
  #19554
Tkay08's Avatar
I just saw Private labal H2b Kit and it look so much like QSD kit! Im still with the QSD no matter what. Is QSD the founder of H2B?
Old 07-24-2013, 06:18 PM
  #19555
Ek Forever y0!
H2B is simply an H motor with a B transmission, it's just phraseology, no one invented it per se.
Seth just jumped into it and developed the best kit there is for the concept
Technically you can do it without a kit, but it's not safe, obviously.
Old 07-25-2013, 02:21 PM
  #19556
gag23118's Avatar
New to this forum, but after 2 months building my h2b finally got it starting. The most crucial part of this build was the REsleeving of the engine with cast iron sleeves after that it was easy. I got to use rdx injectors with a k20z3 manifold with a k24 crankshaft.
Thanks guys with all great info in this thread
heres my vid thanks
Old 07-27-2013, 01:10 PM
  #19557
DrCRX's Avatar
Thanks Adam, the pan will go to good use! Please take care of the cool Hatch, NICE car! Give us a call if you need any thing.
Old 07-27-2013, 08:50 PM
  #19558
BradTheJonez904's Avatar
Greetings from jax,fl. This is a fun setup!
jdm h22a gsr trans rbc intake/64mm tb KR rep header
2.5 exhaust to flowmaster 40 series. comp stg 4 clutch act flywheel
Old 07-29-2013, 12:36 PM
  #19559
Tkay08's Avatar
First H2B H22a4/QSD/ITR/HondataS300
Old 08-06-2013, 07:38 PM
  #19560
tegtuner01's Avatar
Ok so I'm going to pick up a qsd kit on Saturday. The guy says its brand new in box. Just wondering what all I should look for so I'm not missing anything
Old 08-06-2013, 08:55 PM
  #19561
Ek Forever y0!
http://www.quartersportsdrag.com/Kit_Contents.html
Old 08-07-2013, 04:48 AM
  #19562
tegtuner01's Avatar
Oh thanks I guess I overlooked that page on the site
Old 08-08-2013, 09:51 AM
  #19563
deucedeuceEK's Avatar
Anyone by chance have an esp upper 1/2" over alternator kit fs?
Old 08-10-2013, 05:13 PM
  #19564
hybridmiklo's Avatar
I have a 94 del sol. I am seriously debating going h2b since i have all the original b16 swap. I noticed there are a few kits. Which do you guys prefer and which gives you the most clearance on the driverside? Anybody have pics of the clearance and how much "pounding" was done to make it fit with and without the timing covers and balance shaft gear?
Old 08-10-2013, 08:28 PM
  #19565
I'm really 2slow
2fast4u831's Avatar
go to my post, #3 on the link below. It will answer your question. I am using the QSD kit. It leaves the transmission and all components in the original location.
https://honda-tech.com/forums/hybrid-engine-swaps-18/h2b-f2b-faq-1998426/
Old 08-11-2013, 07:51 AM
  #19566
geez thats close. Is there any vibration issues since the balance shaft isnt used?
Old 08-11-2013, 01:11 PM
  #19567
Ek Forever y0!
I haven't had balance shafts for a year and I can't tell they're removed.
Old 08-12-2013, 06:59 AM
  #19568
I'm really 2slow
2fast4u831's Avatar
Can't really tell. I have hasport mounts with race inserts(88a) so everything vibrates. lol.
Old 08-12-2013, 01:34 PM
  #19569
Ek Forever y0!
Yeah I'm running 80a and I hear a fair amount of interior rattling. Everyone tells me the car runs super smooth though. It's totally stock though, no harsh cams or anything.
Old 08-12-2013, 03:57 PM
  #19570
DA is best's Avatar
Old 08-12-2013, 08:06 PM
  #19571
jsinher3's Avatar
hey how did you guys bleed your cooling system on the h2b im having a hard time. it could be too that my thermostat isnt working because it starts to over heat and the hoses gets hard... however, when i open the valve and rev the motor and no coolant comes out, just steam.. what do you guys think?
Old 08-12-2013, 08:20 PM
  #19572
i put up all my bseries stuff and turbo stuff up for sale. I want in this h2b thing. But I have a few more questions before I go into buy mode.
Which h2b is more preferred? Ive seen even bisimoto has a kit.
What axles can I use?
Which mounts do I use?
Anything special with the fuel line I need to do?
Can the engine fit without removing the balance shaft gears?
Sorry if its alot. Ive done hundreds of bseries swaps. But H is a new frontier for me. Thanks!!
Old 08-12-2013, 08:35 PM
  #19573
Ek Forever y0!
QSD is definitely the most popular. It's cheaper and allows more freedom in the use of some parts. It essentially makes the swap a b-series to put it simply.
I use Autozone Axles, 2 autocross seasons and 40,000 miles and they're holding up fine.
B-series mounts. Really.
Not unless you have an Accord motor like me, my fuel line had to be swapped around. Not a big deal.
Removing the balance shaft assembly isn't for fitment, it's to remove 10-14lbs from the rotating assembly, much like taking weight off of the flywheel.
I have an 8lb flywheel and balance shaft removed, my engine revs like crazy.
The QSD kit essentially turns and H22 into a b-series swap. If you get OEM ish axles with pretty narrow shafts you won't have to trim much on the oil pan. Also you'll have better clearance with your hood.
Old 08-13-2013, 07:03 PM
  #19574
I see. seems pretty straightforward. Ive been on qsd website and see what comes with the kit. Getting excited to get this started. Have you gone to a manual tensioner? I see that Kaizen makes a manual tensioner kit which looks way cleaner and gets rid of the long *** tensioner bolt. I am probably just going to remove the balance shaft belt if possible. I just dont want any rediculous vibrations at idle like if I was driving an ef with a bseries.
Any particular h series I should pick up? I see that the SH is totally different and I dont want to mess with it. Its going into an eg. Would it be easier to pick up one same time frame? Arent the dizzy plugs the same? I am going to use my hondata so I plan on using some 440cc injector I have
Old 08-13-2013, 07:45 PM
  #19575
Ek Forever y0!
Manual tensioner and balance shaft delete are a must in my opinion. Definitely the tensioner beyond a shadow of a doubt.
I daily drive mine with no balance shafts and 80a mounts and it's very tolerable. My girlfriend only complains about my suspension.
Quick Reply: **Official H2B Discussion thread **
