Honda S2000 Honda S2000
zero compression
Old Mar 20, 2017 | 12:39 PM
01-0281's Avatar
Default zero compression
hello all, I have a 02 s2000 and recently noticed it sounded a bit off, I took the car in to have a compression test done to find out that cylinder 4 has zero. I was told that my best bet would be to try and find a new motor rather than rebuild it due to cost being roughly the same for both and for the fact that because it hasn't been torn down yet we're uncertain of the reason behind the lack of compression (hole in cylinder/piston). just wanted to get your guys input on this matter as I look to source a new to me motor and tranny combo. thank you.
Old Mar 20, 2017 | 04:15 PM
Greyout's Avatar
Default Re: zero compression
Probably a broken or bent valve?
Old Mar 20, 2017 | 08:39 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Scope the cylinder... maybe you can see if the problem is valve related or piston related.
Old Mar 25, 2017 | 12:56 PM
01-0281's Avatar
both great suggestions. ill try them out and see what I find
Old Mar 25, 2017 | 01:04 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
A rebuild is always better than gambling on a used motor.
Old Mar 26, 2017 | 01:47 PM
01-0281's Avatar
how much does a standard rebuild cost usually?
Old Mar 26, 2017 | 05:28 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
It'll depend on how much you can do yourself, how much a machine shop will have to do and what all is needed. First things first, diagnose the engine and find out why you have zero compression in the one cylinder.
Old May 8, 2017 | 08:23 PM
JustOneOrTwoPosts's Avatar
A good technician will be able to tell you where the loss of compression is coming from and pinpoint where the mechanical issue is... good luck.
Old May 9, 2017 | 11:53 AM
Chance EG's Avatar
Definitely pull the plugs and run a scope. If it's a valve issue that would be worth the time to fix rather than swapping the entire engine.
That's a huge over generalization, and quite possibly not true for a F20C engine. Most members on S2KI are known to prefer engine swaps as opposed to rebuilding blown engines like this since the only viable aftermarket pistons (if that's the issue) are Mahle and those still require some special bore/honing to get installed correctly with the FRM sleeves.
Not to mention if you buy a used engine from a reputable vendor like Hmotorsonline or something similar and make sure it's compression/leak down tested first, you're not even close to taking a "gamble" on it...
Salvage what you can from your current engine regardless of what ends up happening.
Edit: Actually I'm pretty sure you can still even pick up new F22 engines from Honda by certain dealerships. May also be worth looking into that.
kPRO dz
Sep 6, 2009 07:55 PM
street dreams
Nov 26, 2004 12:52 AM
street dreams
Nov 21, 2004 04:48 PM
street dreams
Nov 21, 2004 02:44 PM
prelude994e
Nov 2, 2004 07:42 PM
