Honda S2000 Honda S2000
Write up on how to lower a s2000??????
Old Apr 1, 2005 | 12:32 PM
bonta-kun's Avatar
Default Write up on how to lower a s2000??????
does anyone have the link to where i can find instructions on how to lower a s2000
normally i would just jump into the car and figure it out
but this is a $20k vehicle and we dont wanna mess anything up
so if u have the instructiosn please help me and my friends out
Old Apr 1, 2005 | 12:39 PM
papa5murf's Avatar
Default Re: Write up on how to lower a s2000?????? (Cheer up pedro!!!)
springs or coilovers??? it's pretty simple... same as any other car...
Old Apr 1, 2005 | 12:42 PM
papa5murf's Avatar
Default Re: Write up on how to lower a s2000?????? (03s2kblue)
i just read the other thread. you're doing springs....
you need a spring compressor..... to take the stock spring out... other then that.. quite explanitory. if you've done it on another car... you can do it on this one.....
Old Apr 1, 2005 | 12:43 PM
devnull's Avatar
It's just like lowering a integ or civic. Might be a few differences but not enough to warrent hyper concern. Just take it easy and make sure you put everything back together right.
Oh I heard the fronts are a little tricky to get out cause of the A arms.
Old Apr 1, 2005 | 12:49 PM
papa5murf's Avatar
Default Re: (qi_doy)
yeah it's the same.. yes... it's easier to remove the a arms.. otherwise it's a little hard to get the shocks out..... as for the rear... you'll need to remove the spare tire for the passenger side.... as for the drivers side.. you can remove the gas lines if you want easier access to the shocks... however if you do remove the gas lines and move them out of the way.. make sure you put a rag over the opening so nothing falls in..... and if you do this make sure you got good ventelization...... otherwise you'll be on the floor hahahahahah....
Old Apr 1, 2005 | 01:36 PM
bonta-kun's Avatar
Default Re: (03s2kblue)
ight cool just wanted to make sure didnt want to take off the tires and see some complex shock assembly lol
thanks for the inputs guys looks like were gonna start right now ill post pics when im done
Old Apr 1, 2005 | 01:52 PM
Francesco's Avatar
Default Re: (Cheer up pedro!!!)
can't wait to see
Old Apr 1, 2005 | 05:16 PM
donnie B's Avatar
Default Re: (Francesco)
just cut a few coils out of the spring that will give you your best ride, cause it uses the stock spring still....
becks
Old Apr 1, 2005 | 05:31 PM
Mr. Lucky's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue &raquo;</TD></TR><TR><TD CLASS="quote">i just read the other thread. you're doing springs....
you need a spring compressor..... to take the stock spring out... other then that.. quite explanitory. if you've done it on another car... you can do it on this one.....</TD></TR></TABLE>
spring compressors are a waste of time
Old Apr 1, 2005 | 06:17 PM
papa5murf's Avatar
Default Re: Write up on how to lower a s2000?????? (bs-inc.s2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bs-inc.s2k &raquo;</TD></TR><TR><TD CLASS="quote">
spring compressors are a waste of time </TD></TR></TABLE>
but it helps you keep your teeth in the proper positions hahahaha
Old Apr 1, 2005 | 06:25 PM
bonta-kun's Avatar
we just finished was so easy took us like 10 min per side including taking the tire off
was pretty straight forward we just took the bolts from the top hats then the lower bolt on the control arm
the the two bolts from the a arm then viola we were done YAY
but we didnt get to do the the rears cause he had to leave the spings used were espilier it took longer to drive to auto zone to get the spring compressors lol
were gonna do the rear tommorw all the pics will be up then tanks for the help
Old Apr 1, 2005 | 08:03 PM
papa5murf's Avatar
told ya it was easy
Old Apr 6, 2005 | 02:41 PM
partsguyonline's Avatar
What kinda springs did you use? Like the ride and drop? pics?
Old Apr 6, 2005 | 04:14 PM
neo1z's Avatar
Default Re: Write up on how to lower a s2000?????? (partsguyonline)
You should invest in a shop manual for your car
Old Apr 6, 2005 | 04:20 PM
bonta-kun's Avatar
Default Re: Write up on how to lower a s2000?????? (neo1z)
it was lowered on espleier springs but the rear was hella werid cause of the gas tank thingy hella got in the way
Old Apr 6, 2005 | 04:30 PM
Nishant's Avatar
i'm gonna do a write up on a coilover install soon. not sure if it will help but you can take a look
turboeg954
Honda S2000
Dec 27, 2011 12:19 PM
frostyloon
Honda S2000
Jan 14, 2008 02:39 PM
dalilenginedatcud
Jul 17, 2007 12:59 PM
Scotty Dosent Know
Honda S2000
20
Nov 4, 2006 08:59 AM
BassBoy19
Honda S2000
19
Mar 11, 2004 07:12 AM
