Honda S2000 Honda S2000
Will this offset work?
Old Aug 2, 2005 | 05:32 PM
neo1z's Avatar
Default Will this offset work?
If there is one thing I am really bad at, its offsets and the like.
BOLT PATTERN 5X114.3
THE SIZE IS 17X8 OFFSET +35 IN THE FRONT AND 17X9 OFFSET +35 IN THE REAR.
So +35 +35 - I really dont know. I know it seems a little unusual. Let me know if it would possibly work guys - thanks.
Old Aug 2, 2005 | 05:33 PM
neo1z's Avatar
Default Re: Will this offset work? (neo1z)
Is +43 in the rear better?
Old Aug 2, 2005 | 05:37 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Unless it`s something ultra jdm extra rare, it`s really not worth it.
Modified by vtecvoodoo at 7:04 PM 8/2/2005
Old Aug 2, 2005 | 05:50 PM
humanshield's Avatar
Default Re: Will this offset work? (vtecvoodoo)
you'd need an ultra wide body kit.
Old Aug 2, 2005 | 09:43 PM
ken-e's Avatar
Default Re: Will this offset work? (humanshield)
you can use them, but you wont be able to dump your car
(if your into that )
if you are, you can roll your stock quarter panels or get aftermarket ones...
Fronts should be fine.
Old Aug 2, 2005 | 10:50 PM
neo1z's Avatar
Default Re: Will this offset work? (ken-e)
Do I need +48 or something in that arena?
Old Aug 3, 2005 | 04:15 AM
aklucsarits's Avatar
New User
You cannot simply say that a +xx mm will work because correct offset will depend on the wheel width too.
Use this calculator:
http://www.1010tires.com/WheelOffsetCalculator.asp
Andrew
Old Aug 3, 2005 | 06:29 AM
Scot's Avatar
at least you got the right bolt pattern!!! ahahah
the stock rears are 7.5 wide with a 65mm offset....your 9" wide 35mm offset wheels would stick about 2.25" further out than the stock wheels.
In the GHETTOOOOOOOO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo1z &raquo;</TD></TR><TR><TD CLASS="quote">If there is one thing I am really bad at, its offsets and the like.
Old Aug 4, 2005 | 10:02 AM
neo1z's Avatar
Default Re: Will this offset work? (Scot)
Thats why I was asking lol.
Old Aug 4, 2005 | 08:43 PM
papa5murf's Avatar
35 will not work... 43 will not work either........ 45 is iffy....... people pull off 48 on a 7-8inch width.....
Old Aug 5, 2005 | 04:42 AM
Scot's Avatar
Default Re: Will this offset work? (03s2kblue)
Volk TE37's are generally 17*8.5 with 48mm offsets and work just fine with 245's even when lowered (unless you try to squeeze a huge tire on it).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue &raquo;</TD></TR><TR><TD CLASS="quote">35 will not work... 43 will not work either........ 45 is iffy....... people pull off 48 on a 7-8inch width..... </TD></TR></TABLE>
Old Aug 5, 2005 | 06:01 AM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scot &raquo;</TD></TR><TR><TD CLASS="quote">Volk TE37's are generally 17*8.5 with 48mm offsets and work just fine with 245's even when lowered (unless you try to squeeze a huge tire on it).
why get a 8.5? when they specifically make a 9 for the S.. (thanks to evolution)
CDN Yellow ITR
Jul 24, 2006 04:53 PM
arbys2k
Honda S2000
Jun 30, 2005 04:48 AM
Nick H
May 10, 2002 04:20 PM
kkim
Jan 14, 2002 10:19 AM
