Honda S2000 Honda S2000
when engine is cold??
Old May 11, 2007 | 05:53 PM
vishalhonda's Avatar
Default when engine is cold??
i just tried racing the car with cold engine , but seemed to sort of cut out at 7rpm, is this meant to happen when engine is cold, never happens when engine is at normal temp?? thnx for your comments
Old May 11, 2007 | 06:07 PM
Jimihendrix's Avatar
Default Re: when engine is cold?? (vishalhonda)
I've heard something about Vtec not kicking in when the engine isn't at a suitable opperating temp? Is that what you mean? I should point out, that was a B16A2 EK Civic VTI unit that applied to, not sure if its the same for an S2000 unit.
I could be wrong though.
Oh yeah. Racing a cold motor will ***** it up goodo..... so don't.
Modified by Jimihendrix at 7:35 PM 5/11/2007
Old May 11, 2007 | 06:20 PM
b20integrapower's Avatar
Default Re: when engine is cold?? (Jimihendrix)
why did you even attempt to race on a cold engine?
Vtec wont engage on a cold motor, and i think it cuts fuel too at a certain rpm.
Old May 11, 2007 | 06:21 PM
ITRbroham's Avatar
shit post warrior
Let the engine temp reach normal operating temp.(3 bars) before revving it past 3k rpm, PLEASE!
Old May 11, 2007 | 09:34 PM
iball16's Avatar
The S has two fuel cutoffs. One right at Vtec and another at redline. The First is to prevent damage by the driver if the engine is cold. Let it get to 3 bars before getting into it!
Old May 13, 2007 | 11:42 AM
Default Re: (iball16)
cheers guys!! learn summin new evryday!! lol, as u can see im a beginner to all this!
Old May 14, 2007 | 12:56 PM
s2k5's Avatar
u shouldnt even rag ur car when its cold its better with every manual car that u warm it up i always warm it up to 4 bars min if not ur gona end up with tapping valves that tit tit tit sound its horrible~~!
but u should always warm up a manual car at all times~~~!!! weather it be a S or not its good for the motor
Old May 14, 2007 | 01:18 PM
1siks2k's Avatar
Default Re: when engine is cold?? (s2k5)
My S2K has NEVER hit 4bars of heat and I live in *** HOT AZ! hrmmmm
Old May 14, 2007 | 03:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2k5 &raquo;</TD></TR><TR><TD CLASS="quote">u shouldnt even rag ur car when its cold its better with every manual car that u warm it up
but u should always warm up a manual car at all times~~~!!! weather it be a S or not its good for the motor </TD></TR></TABLE>
You should warm up an auto as well (although S2K's dont come in auto...THANK GOD!!!) duh. Just because its got a slush box in the floor dosnt mean you can thrash right away! Lol!
I'm sure thats not how you meant to come accross but just incase anyone read it and thought it was okay to thrash a cold engine as long its auto tranny.
Old May 14, 2007 | 03:57 PM
Techno Tonis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vishalhonda &raquo;</TD></TR><TR><TD CLASS="quote">i just tried racing the car with cold engine , but seemed to sort of cut out at 7rpm, is this meant to happen when engine is cold, never happens when engine is at normal temp?? thnx for your comments</TD></TR></TABLE>
always let it warm up.
Old May 15, 2007 | 10:04 PM
iam7head's Avatar
Default Re: when engine is cold?? (1siks2k)
you are not driving hard enough, there's a dude was doing canyon and blew coolant all over all place. he was on top of 2nd gear for a good 30 miunte and his grille is plugged with a plate and apc mesh
Old May 16, 2007 | 03:36 AM
gldnchildek9's Avatar
Default Re: when engine is cold?? (iam7head)
isn't the reason Honda but the limiter there because there isn't sufficient oil pressure in the motor therefor vtec cant operate. naturally the oil has way better flow when its warm/hot to flow through the passages.
Old May 16, 2007 | 04:11 AM
WowOzYouRock's Avatar
Default Re: when engine is cold?? (gldnchildek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gldnchildek9 &raquo;</TD></TR><TR><TD CLASS="quote">isn't the reason Honda but the limiter there because there isn't sufficient oil pressure in the motor therefor vtec cant operate. naturally the oil has way better flow when its warm/hot to flow through the passages. </TD></TR></TABLE>
how about ... ROFL
oil pressure would be the same from the moment you start the car ... if it go below the spec, the car will start to bug... if its has significantly drop, the car will shut off to prevent engine damage..
Old May 16, 2007 | 06:02 AM
JDM knowledge's Avatar
Default Re: when engine is cold?? (FR-MOB: Jerk)
i think you might have scratched your cylinder walls. Be careful son
Old May 16, 2007 | 08:36 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Jerk &raquo;</TD></TR><TR><TD CLASS="quote">
how about ... ROFL
oil pressure would be the same from the moment you start the car ... if it go below the spec, the car will start to bug... if its has significantly drop, the car will shut off to prevent engine damage.. </TD></TR></TABLE> i didnt even think about that... thanks for the correction
Old May 17, 2007 | 06:03 PM
- BSeRiouS -'s Avatar
Default Re: when engine is cold?? (JDM knowledge)
Stupidity. Blah.
Only drive your car hard when you have 3 bars on your temp gauge. I believe it also does that as a saftey precaution too when cuts off at a certain RPM so it won't F' anything up when people do that.
Old May 18, 2007 | 06:25 AM
Sean Juan's Avatar
Default Re: when engine is cold?? (OBSeRiouSo)
That is correct. Why would you race on a cold engine?
69GTOby
Apr 28, 2013 10:02 AM
televascular
Apr 11, 2006 07:14 AM
GSRVTEC1
Nov 29, 2005 10:31 PM
JadeDM
Feb 18, 2004 08:46 AM
