Honda S2000 Honda S2000
What size test pipe?
Old Jul 27, 2010 | 04:39 PM
eric416's Avatar
Default What size test pipe?
How do i determine what size test pipe to go with? I already have a magnaflow exhaust which i think is 2.5" pipe. Would i benefit going with a 70mm or 63mm? I also want it to have the cel fix. Any opinions?
Old Jul 29, 2010 | 09:02 AM
Jspd's Avatar
Default Re: What size test pipe?
With the diameter of your exhaust I would stick with a 63mm TP. Any brand will do so just go with whats cheaper. You will just need two spark plug defoulers from Autozone for the O2 sensor fix. Just drill one of them out to fit the sensor in and then screw them together and you are good to go
Old Aug 12, 2010 | 09:40 AM
92HB_HB's Avatar
I have one when you're ready to buy.. w/ the CEL fix too.. Mine's never came on w/ it in use..
Old Aug 13, 2010 | 09:58 PM
zimmy709's Avatar
the same diameter as your exhaust
Old Aug 14, 2010 | 08:50 AM
Memo6453's Avatar
i have a BERK 63.5 mm if you want it, also with CEL fix. PM me for info.
I only had it on my car for like 400-500 miles, then i went with a 70mm Exhaust and switched to a 70mm TP.
Old Aug 14, 2010 | 08:58 AM
Kyle R's Avatar
Old Aug 14, 2010 | 09:08 AM
JDMF22B's Avatar
The same, or smaller. However do NOT go larger.
Old Aug 14, 2010 | 01:12 PM
Ellerstein12's Avatar
I agree get one that is the same size as your exhaust.
Old Aug 16, 2010 | 12:45 AM
S2K-APWON's Avatar
I would go with a 63mm TP for a better flow.
Old Aug 16, 2010 | 07:09 AM
White Smoke's Avatar
i my honda
Global Mod
Stick with the 60 or 63mm test pipe with that exhaust.
lame05
Honda Civic (2001 - 2005)
Mar 15, 2013 08:54 AM
spunautosports
Oct 20, 2006 10:22 AM
PurpleGsR00
Jun 16, 2002 10:13 PM
ITR #1202
Dec 2, 2001 11:57 AM
