Honda S2000 Honda S2000
vibration when accellerating
Old May 5, 2008 | 05:26 AM
SLUGNIKEL608's Avatar
Default vibration when accellerating
Hey, I have recently replaced rear differential on 2001 S2k, and now upon acceleration I am getting a bad vibration. Could this be the driveshaft not being
mounted exactly in the same mounting position that it was removed from or could
axles be going bad. Hmmm, any suggestions on what I might need to try would be helpful.
Modified by SLUGNIKEL608 at 6:50 AM 5/5/2008
Old May 5, 2008 | 08:12 AM
Soul Coughing's Avatar
sounds like it could be that. Do you hear any clicking from the axles when starting out from a stop? Did you align them to the yellow paint?
Old May 5, 2008 | 08:46 AM
m R g S r's Avatar
Default Re: vibration when accellerating (SLUGNIKEL608)
It's kinda hard for the driveshaft to be mounted off center....
Old May 7, 2008 | 06:03 AM
Default Re: vibration when accellerating (m R g S r)
its not mounting it off center, but mounting it with the yellow paint matching up on the input flange of the diff and flange of the drivetrain! They are speed balanced by honda, and the yellow paint is there to get the least amount of rotational inbalance! What did you do to break the original diff? any launching? the axles may be bad too!
Old May 8, 2008 | 11:10 AM
S2K K1DD's Avatar
Its most likly the Axles are done my boys S2 did the same thing under accel.....
Old May 8, 2008 | 11:12 AM
iam7head's Avatar
Default Re: (S2K K1DD)
well, the drive shaft need to be balanced if you having a bad vibration
Old May 8, 2008 | 11:24 AM
Techno Tonis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLUGNIKEL608 &raquo;</TD></TR><TR><TD CLASS="quote">Hey, I have recently replaced rear differential on 2001 S2k, and now upon acceleration I am getting a bad vibration. Could this be the driveshaft not being
Modified by SLUGNIKEL608 at 6:50 AM 5/5/2008</TD></TR></TABLE>
Clutch Buzz?
Old May 9, 2008 | 11:46 AM
rice4life's Avatar
Default Re: vibration when accellerating (Techno Tonis)
clutch buzz only happens on deceleration.
if your drive shaft or axles are imbalance, you should get vibration at certain speed regardless of acceleration or deceleration like imbalance tires.
Old May 9, 2008 | 12:04 PM
ok, thanks...
It mostly does it on acceleration between say 40-65mph. After that 70+ mph
it really smooths out. I didn't know about the yellow lines for alignment..so that's
probably it..(i hope). It ran smoothly until I put the new rear diff in. I will try and
see the "yellow" lines and get them lined up and see how that does. Any other
recommendations are appreciated as well. Oh by the way..I sheared a gear completely off my old diff and cracked all the rest of them. So that's the reason for
the new diff. in the first place. But normally don't drive it hard..Daily driver mostly
for me.
VDM_DC2
Suspension & Brakes
11
Oct 28, 2009 12:28 PM
IntegR
May 7, 2006 03:41 PM
skunk2powered
Sep 4, 2004 02:09 PM
MHhonda99
May 6, 2002 07:42 AM
