Honda S2000 Honda S2000
VAFC prob! Pls help
Old Aug 20, 2004 | 07:37 AM
Takashi1978's Avatar
Default VAFC prob! Pls help
Hi,
I'm asking this for my friend. He has a JDM S2000 in Malaysia. He is running a Spoon ECU with Gen-1 VAFC.
We got it tuned at the dyno and the odd thing is,after we dial in everything,after a few runs, the A/F goes all around the place.Like it's reseting itself.
I looked in the manual,it doesnt list it for the AP1.
Whats the problem?
Will getting a VAFC-2 be better?
Old Aug 20, 2004 | 09:31 AM
Mr. Bagel's Avatar
Default Re: VAFC prob! Pls help (Takashi1978)
what else is done to the car?
Old Aug 20, 2004 | 06:18 PM
Default Re: VAFC prob! Pls help (Mr. Bagel)
Mugen header
Tanabe catback
ARC intake
Ground wire
Thats it.
Old Aug 20, 2004 | 07:37 PM
evil vapor's Avatar
is the VAFC wired in properly? no shorts, no exposed wires?
Old Aug 21, 2004 | 03:58 AM
Default Re: VAFC prob! Pls help (vapor)
Coz there is no wiring diagram for the AP1 when the 1st gen VAFC came out,we had to follow the closest ecu match we could find.
The wires areall in tact.
Old Aug 22, 2004 | 12:25 AM
SuzukaBlueAP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takashi1978 &raquo;</TD></TR><TR><TD CLASS="quote">Coz there is no wiring diagram for the AP1 when the 1st gen VAFC came out,we had to follow the closest ecu match we could find.
The wires areall in tact.</TD></TR></TABLE>
Just because there was no printed wiring schematic for the AP1, doesn't mean it's not compatible.
If you found all the correct wires on the ECU, then there should be no reason why it doesn't work right.
You should've found a proper:
Power wire
Ground (in which 2 wires connect to)
RPM signal
Pressure signal
Throttle signal
and you need the wires for the VTEC signal.
I think that's about it...did you make sure you had all the right wires for those?
Old Aug 22, 2004 | 12:27 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takashi1978 &raquo;</TD></TR><TR><TD CLASS="quote"> Like it's reseting itself.</TD></TR></TABLE>
Just read this again...since it is after 4 in the morning, i'm not functioning right. lol
Anyways...so it acts LIKE it's resetting, but is it actually doing so?
Old Aug 22, 2004 | 05:58 AM
Default Re: VAFC prob! Pls help (ScreaminTeg)
Yes it is actually.After we dial i the settings, after a few runs, the a/f will change.
we're thinking it has something to do with the Spoon ECU.
But he doesnt have his stock ecu anymore and there is i think less than 10 S2000 in the whole city.Too bad we dont know anyone who owns one.
Right now we are trying to find a stock s2000 ecu from the junkyard.
burntbinsd
Feb 20, 2007 03:53 AM
dzzrunnin411
Jan 20, 2007 10:35 AM
billyhoe
Dec 23, 2004 12:48 PM
tyflip2
Dec 3, 2003 05:53 PM
zCivic
Oct 1, 2002 08:26 AM
