Honda S2000 Honda S2000
trunk problem on my ap1
Old Apr 21, 2012 | 04:19 PM
em1effekt's Avatar
Default trunk problem on my ap1
just baught this ap1 about two weeks ago....
i noticed the trunk doesnt open with the trunk button...only opens with the key...
i checked the trunk and all i notice it has like 2 harnesses and one is not plugged in..but i dont see any conection for it...
also notice the latch doesnt have any wire attached to it like the hood or trunk of my civic...
all i found when searching was that the trunk and light didnt work turned out being the wiring..in my case the third light works and theres 2 plugs?
Name:  s2k trunk.jpg
Old Apr 21, 2012 | 05:51 PM
fernando.'s Avatar
Default Re: trunk problem on my ap1
I know this sounds stupid, but are you holding the button for ~5 seconds?
Old Apr 22, 2012 | 12:25 AM
em1effekt's Avatar
no i didnt i would just press it once .....didnt know about that just baught the car using it as my daily driver =] i had also just found out like two days ago where the fuel cap button was at and that the ebrake has to be up for the top to go down...
ill try that tomorow thanks
Old Apr 22, 2012 | 07:39 AM
fernando.'s Avatar
Yeah, you need to hold the button down for a few seconds.
Old Apr 22, 2012 | 03:29 PM
em1effekt's Avatar
i tried that now and still didnt open....
i looked up ''s2000 trunk latch'' on google..and it shows a latch with a plug on it..
so im assuming the plug hanging in the picture above is suppose to connect to it..im going to check if mine isint cut
question; do the trunks have the cord that controls the latch?...for example like the hood? kinda looks like the throttle cable? is mine suppose to have that in the trunk?
Old Apr 22, 2012 | 11:49 PM
em1effekt's Avatar
ok after doing some search on google...and some thinking i found out that the hanging harness is suppose to plug into my latch but my latch for some reason is missing the conection...my latch is missing what is circled in yellow below..
Old Apr 23, 2012 | 07:12 AM
Black S2K's Avatar
r u sure u can just find it it would be behind the latch
Old Apr 23, 2012 | 07:42 AM
em1effekt's Avatar
That's what I was thinking so I removed the latch and it doesn't have it..you can see in my pic on the first post..its completly missing..
Old Apr 23, 2012 | 09:05 AM
Black S2K's Avatar
weird
Old Apr 26, 2012 | 06:25 PM
JDM.Brown's Avatar
The trunk might have been replaced and maybe someone didn't install all of the parts correctly. Does the VIN sticker on the trunk match the VIN on the car?
Old Apr 26, 2012 | 08:09 PM
fknfast's Avatar
more pics
Old Apr 26, 2012 | 10:22 PM
em1effekt's Avatar
im sure my latch is missing that part that connects to that plug..
just to make sure can anyone post a pic of there latch
Old Apr 27, 2012 | 06:46 AM
Black S2K's Avatar
have u removed ur latch to c?
Old Apr 27, 2012 | 08:20 AM
em1effekt's Avatar
Yeah they match...just my latch seems to be broken..and the owner didn't replace it cause he would open it with the key...but I baught a cf trunk and it eliminates the key cylinder so I have to replace the latch before I install the trunk
Old Apr 27, 2012 | 08:21 AM
em1effekt's Avatar
Yeah I did....the part that has the harness is broken off the latch...I have to find a new latch
Old Apr 27, 2012 | 09:06 AM
HondaKyle's Avatar
You should post some info and pics about your CF trunk. Ive been looking at getting one.
Old Apr 27, 2012 | 10:12 AM
em1effekt's Avatar
Not really any info...the one I have is seibon..and it eliminates the key cylinder so I won't be able to open it with the key anymore...I heard some people install an emergency button using the same latch incase the stock one stops working because they won't have acess to the the trunk but I still need to read up on how to do that...
Old Apr 29, 2012 | 04:08 PM
Marty Mercurio's Avatar
Dunno
Old Apr 29, 2012 | 10:14 PM
em1effekt's Avatar
Originally Posted by Marty Mercurio
Dunno
I think this threads been over since I found the problem a while back
funkijunki
Aug 29, 2004 07:55 AM
88EF96EK
May 24, 2003 04:28 AM
JDubya
Mar 13, 2003 07:44 PM
The Kegger
Jan 9, 2003 12:10 PM
IntegraT
May 23, 2002 02:45 PM
