Honda S2000 Honda S2000
Tranny binding ?
Old Jan 10, 2005 | 03:41 PM
GradyDC5's Avatar
Default Tranny binding ?
Well the tranny is completely seperated from the block with more than 1/2 an inch around the whole thing. The only problem is it's binding on something, and we can't figure out how to unbind it. Has anyone ran into this problem ? I've tried multiple pry bars to pry the tranny back. It just goes back a certain distance, and stops wont go any further.
I've taken the airbox,heat shield,header, cat, propellar shaft, sensors, wires, bolts, starter, altenator, subframe, and just about everything else. I've ran out of ideas so I've ordered a helms to try and help.
Suppose to be one of the best cars Honda has built. I think it's the worst to work on hands down. Everything was made to be a pita
Old Jan 10, 2005 | 03:43 PM
GradyDC5's Avatar
Default Re: Tranny binding ? (ReallySlowEg)
Side note- got my head studs and golden eagle b20/vtec oil line kit put on my b20 block and gsr head. The car pissed me off so bad had to redeem myself somehow, and pretend that i'm master mechanic
Old Jan 10, 2005 | 04:30 PM
Nishant's Avatar
sure you got the right forum?
Old Jan 10, 2005 | 04:58 PM
GradyDC5's Avatar
I figured since this is an S2000 forum. I would get a more direct answer to my question.
Old Jan 10, 2005 | 06:25 PM
Nishant's Avatar
Default Re: (ReallySlowEg)
which tranny you using? one from a s200 and you're putting it with a B20?
Old Jan 10, 2005 | 06:48 PM
97ShLude's Avatar
To get the tranny off you have to jack up the front of the engine to tilt the tranny downward a little. It's probably getting held up by the firewall.
EGhatch1189
Dec 5, 2009 07:34 AM
blacc_ej1
Transmission & Drivetrain
Nov 12, 2008 11:48 AM
duquetco
Jan 27, 2008 03:29 PM
WGFletch4WS
May 30, 2007 11:08 AM
Rpc07
Aug 28, 2003 10:10 PM
