Honda S2000 Honda S2000
TEIN S-Tech's
Old Dec 30, 2008 | 05:18 PM
AP1BBs2k's Avatar
Default TEIN S-Tech's
Hey guys sorry but this has probably been asked before but i have recently purchased an S about two months ago and was wondering if anyone here has TEIN S-Tech lowering springs on their car. I want to give my car that 1 inch drop look but have heard it can mess with my stock springs and harm my handling? i was just wondering what the S community thinks about this. I also have heard these are decent if im not going to track it or autocross it. I dont know if i want to spend 1600 on FLEX coils for just the look but i can use any feedback. If i know the Stech's are good for my car i can totally use the money for t1r dual exhaust 70EM. THANKS GUYS! HAPPY NEW YEARS!
Old Dec 30, 2008 | 05:21 PM
EK_B's Avatar
Default Re: TEIN S-Tech's
???? They REPLACE your stock springs.
Old Dec 30, 2008 | 05:44 PM
AP1BBs2k's Avatar
Well thanks for the Education (nosarcasm) im noob with cars sorry. But do you know if Stechs are decent for what im trying to accomplish? Just trying to get that dropped look with about stock handling/driving. nothing to serious. Thanks again!
Old Dec 30, 2008 | 06:00 PM
Sikocivic's Avatar
I have a set on my S2k. It rides good and handles just fine. It will give about a 1" drop.
Old Dec 30, 2008 | 06:03 PM
lucky13AP2's Avatar
i got a set of these on my car and it does give a nice look that your looking for, but you sacrafice comfert, the ride is going to be a lil more rough
Old Dec 30, 2008 | 06:38 PM
EK_B's Avatar
The S - Tech's are meant to be a comfort spring, so they shouldn't be too harsh of a ride. Hopefully the pic above will help you seal the deal.
Old Dec 30, 2008 | 07:21 PM
AP1BBs2k's Avatar
thanks for the input. the drop looks nice and aggressive. Im worried about the comfort and the rough ride, but i dont think it would change dramatically will it? nice RIO btw
Old Dec 30, 2008 | 09:21 PM
lucky13AP2's Avatar
i kno these arent that great of pix but heres how my ap2 sits with the tiens
Old Dec 30, 2008 | 10:10 PM
AMF Racing's Avatar
can't go wrong with them. ride is tiny bit firmer than stock, but nothing major. i love them. here they are on my car.....
Old Dec 31, 2008 | 09:32 AM
S2KFTW's Avatar
I bought my S with the S tech's on it already and I didn't know they were on at first. the drop is only about an inch and from the ride I didn't know it wasn't stock. it wasn't until I jacked up the car to change the oil that I noticed it seemed a little low to fit the jack and then I saw the springs. here's how my car sits with the S Tech's...
Old Dec 31, 2008 | 10:04 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
They replace your stock springs, so they won't affect the stock springs. You will absolutely need an alignment. Don't forget to clock your bushings. If you're having a shop do this, tell them to clock your bushings. Hopefully (if they're a decent shop), they will know what you mean.
My friend has them on his S. They're very very comfortable as far as the plushness goes. The car feels like stock as far as bumps go. My car is on KWs...and driving his car is like driving my car with a flat tire. It's squishy and kind of jiggly/squirmy when you turn the wheel or make sharp corners. That seems to be the characteristic of tein springs for some reason. Too soft, too jiggly. To me, that's not comfortable overall. It may get kind of annoying.
There are other springs that may serve you better. The Espelier ASD drops the car around 1'' also. Those come highly recommended....but I've never ridden on them.
I'm getting the same exhaust, btw.
Old Dec 31, 2008 | 01:43 PM
AP1BBs2k's Avatar
thanks for all the info. What's clock brushings? andill make sure to mention it. nce rides. i shall post my pictures soon.
Old Dec 31, 2008 | 02:42 PM
Sean Juan's Avatar
They wont wear on your shocks that much faster than oem springs to be honest. They're not aggressive enough. I can assure you this. The ride is also not even that noticeably harsher. Just imagine your oem springs, with the car lowered an inch at most all the way around.
Old Dec 31, 2008 | 03:09 PM
ntensehonda's Avatar
I've got Koni yellow shocks that make the car sit about 3/8" lower.
Alignment will be a MUST if you do anything to the suspension at all...unless you like buying tires every 7000miles.
Old Dec 31, 2008 | 03:33 PM
B serious's Avatar
If my tires lasted 7k miles, It would be insane. I'd say I'll get around 2500 miles max. I have about 1k on them and they're around 40% gone. 3 track days on them, though. hee hee.
OP: Clocking bushings is tightening the bushings while the car is at ride height. You have to do it with any non floating bushing or they will eventually tear. Bushing prices for the S2000 aren't cheap.
You need to clock
Front: UCA to chassis, LCA to shock, LCA to chassis.
Rear: UCA to chassis, LCA to shock, LCA to chassis (both at the obvious spot and the not so obvious spot behind the seat), and the other arms that have bushings.
Let's say you're working on the Right rear.
1.) Leave the affected bolts loose or loosen them. Have the car up on 4 jackstands or a lift.
2.) Place a jack underneath the right rear LCA furthest away from the chassis, closest to the hub. You can lift on the balljoint stud if your jack has a rubber protector pad.
3.) Lift till the car comes up off the jackstand.
4.) Tighten all the bolts in the RR corner that are mentioned above.
5.) Lower the car back on the jackstand and do the other 3 corners.
Old Jan 1, 2009 | 03:20 PM
Never heard of this clocking before. Only bushings I messed with were where the shocks mount.
Guess I'll have to double check them, but the car's been lowered for 1.5yrs and I have inspected the underside of the car periodically and have never noticed any problems.
Old Jan 1, 2009 | 06:35 PM
MidwestAutoWorks's Avatar
i have a brand new set of tein s techs i bought from yoparts i am willing to sell at 165 shipped.
Old Jan 1, 2009 | 07:21 PM
MR aK's Avatar
is clocking the bushings the same as preloading the suspension so the springs settle???
Old Jan 1, 2009 | 10:00 PM
B serious's Avatar
Nope.
The bushings are clocked to the factory ride height when the car is built. You had to have loosened other bolts to get the old shocks out. For the front, you probably had to remove the UCAs
You have to clock them to the current height regardless of if you loosened them up during the install or not.
Old Jan 2, 2009 | 01:42 AM
AP1BBs2k's Avatar
why are you selling them? dont like them?
Old Jan 7, 2009 | 11:36 AM
jroland's Avatar
def i have tein springs on my car i wouldnt go any other way
Old Jan 8, 2009 | 07:20 PM
No sold the s2000 before i put them on, they are brand new in box
Old Jan 9, 2009 | 01:22 AM
AP1BBs2k's Avatar
you still have them?
Old Jan 9, 2009 | 04:26 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
midwest is a stand up guy...
s-techs are a good product... enjoy them...
def get an alignment after you put them on...
p-p-porkchop
May 19, 2007 12:35 PM
GoonieAsian
Honda Civic (2001 - 2005)
17
Dec 31, 2006 08:52 AM
4drfool
May 9, 2006 10:25 PM
SilvRGsR
Mar 28, 2004 02:19 AM
xjohnx
Aug 26, 2001 08:19 PM
