Honda S2000 Honda S2000
Tein Flex install question
Old Mar 19, 2005 | 03:38 PM
boostcrazy19's Avatar
Default Tein Flex install question
just wondering if I can get some basic info on the pre-install of my flexs. I've had the coils for three months now and the weather is just starting to get warmer to where I can actually get my lazy *** outside and do this. I read the instructions but it did not tell me much. I want to do this myself b/c here in South Cacalak, there is no one worthy that I know of that can install these.
The coils come pre-assembled and everything.....so do I just remove the factory struts and springs and bolt the flexs directly or do I have to make some adjustments i.e. the spring load, etc. I need ALL the little and vital information possible so that I don't screw up or have to reinstall later.
The EDFC doesn't look to hard at all.... hopefully i can figure it all out. Thanks for the help !
Old Mar 19, 2005 | 03:57 PM
papa5murf's Avatar
Default Re: Tein Flex install question (boostcrazy19)
well...
1. it's a direct bolt on.. if you know hot to take your stock ones off you're fine... so take the stock off and insert teins...
2. make sure you put them on the right side.. there should be little stickers on each assembly which tells you which side and where it goes.. fr, fl, rr, rl.......
3. the edfc is also simple... make sure you follow instructions perfectly... on the threading and dropping in the new screw thingie and greesing it up yada yada.... and how many clicks to move the thing before doing the setup.....
4. to do the rear drivers side...... it's wise to undo the gas tubes and move them out of the way so you have more area to work.. and it'll help when installing the edfc motors.... (make sure you put something over the hole so nothing falls in.. and do this outside cause it's very toxic hahahah)
5. as for wiring... the two rear ones can be fed though easily ... there's little pannels behind the seats that you can take off and you can see right though to the trunk.....
6. for the front wires.. this is a little more tricky.... i found a hole in the firewall on the drivers side... it's like right above the clutch petal... i fed both wires for my front motors though this hole.. it's a tight fit but it fits... and make sure you put the cap back on to keep water out ... .....
once the wires are inside the cabin you can wire it and put it wherever you want....
any more questions just pm me....
i did the complete install in about ehhh 4 hours....
Old Mar 19, 2005 | 04:38 PM
terd ferguson's Avatar
Try this out for tips on removing your stock suspension...
http://forums.s2ki.com/forums/...66520
If you're not up to doing it yourself, P1 auto is just outside Charlotte, NC and are more than qualified to do the install for you. I highly reccomend P1. Try this for contact info...
http://www.p1auto.com
Either way, good luck and take some pics when you're done.
Old Mar 19, 2005 | 08:09 PM
Francesco's Avatar
Default Re: Tein Flex install question (terd ferguson)
also, you have to remove the front A arms to get the old struts off. be carefull when you take off the brake lines, watch the ABS sensor...
Old Mar 20, 2005 | 04:00 AM
Default Re: Tein Flex install question (Francesco)
Thanks for the help ! I did call Jack at p1 auto and he wanted to charge me $600 to do this. I wasn't up for that. I can do it myself, its just that I barely get time with college/work. I was willing to pay like $300 for someone to do it, but no one that had experience took my offer. If it is just simple bolt-off and bolt on for the coils, should have no problem. Francesco, I installed springs on my MY00 about 6 months ago b4 selling it. I never took off the A arms. Or was I just lucky?
Old Mar 20, 2005 | 08:48 AM
papa5murf's Avatar
it makes it easier to take out and put in the coils if you undo the a-arm bolt so you can move it down.... .
Old Mar 20, 2005 | 08:45 PM
bridow's Avatar
Default Re: Tein Flex install question (03s2kblue)
$600 to install? yikes! you can do this in two hours(shocks install) with the help of a buddy and an air ratchet.
a BIG tip is to search online on maybe s2ki.com for the proper heights for your coilovers. i had flex'es on my old wrx and the instruction numbers were goofy. this will keep you from having to install and reinstall your car to find the right ride height. and yes, watch out for the abs lines...they are major bling. i think 200-300 a pop. i havent done the edfcs but hope to install some when i upgrade to RAs on my s2k. good luck!
Old Mar 20, 2005 | 09:24 PM
papa5murf's Avatar
Default Re: Tein Flex install question (bridow)
edfc doesn't work with RA's on the S... only the FLEX....
Old Mar 21, 2005 | 11:27 AM
Francesco's Avatar
heres a heads up on the EDFC...their is a rumor that tein has a wire less EDFC in the making
wish it was out when i did mine, EDFC install takes a lot of patience, but im very **** and had to do it right
Old Mar 21, 2005 | 11:39 AM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">heres a heads up on the EDFC...their is a rumor that tein has a wire less EDFC in the making
wish it was out when i did mine, EDFC install takes a lot of patience, but im very **** and had to do it right </TD></TR></TABLE>
lazy
Old Mar 21, 2005 | 12:11 PM
papa5murf's Avatar
it's not that much of a pain hahahahaha..
Old Mar 21, 2005 | 03:20 PM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue &raquo;</TD></TR><TR><TD CLASS="quote">
it's not that much of a pain hahahahaha..</TD></TR></TABLE>
haha. i think it took me over 4 hours to run the wires and hide them...but then again, i probably took 25 breaks and was very **** with the install and how perfect i could get it...
Old Mar 21, 2005 | 04:54 PM
papa5murf's Avatar
hahaha. where did you put the edfc?? i gotta see your install.. i ended up installing mine in about an hour and a half... and i see no wires...
Old Mar 22, 2005 | 05:09 AM
Francesco's Avatar
mines in the center console. i had to run wires all over because i taped it directly into that fise pannel under the dash. i had to wrap all the wires up and tie them down so they wouldn't hit my legs when i drive...
Old Mar 22, 2005 | 08:07 AM
papa5murf's Avatar
so you got it in the same spot i do??? i hardwired it to my hazards button and my soft top up/down button.... so running the wires was easy..
Old Mar 22, 2005 | 08:21 AM
Nishant's Avatar
does the edfc work withany tein coilover? like the RA's
Old Mar 22, 2005 | 11:01 AM
Francesco's Avatar
Default Re: Tein Flex install question (Nishant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">does the edfc work withany tein coilover? like the RA's</TD></TR></TABLE>
i don't think so. i think someone modded the ra's though to use the edfc
Old Mar 22, 2005 | 12:14 PM
Nishant's Avatar
i don't think so. i think someone modded the ra's though to use the edfc</TD></TR></TABLE>
not worth it then
Old Mar 22, 2005 | 02:20 PM
papa5murf's Avatar
only certain cars have the ability to use the edfc with ra's, and the other tein coilovers....but for the s2000, you can only use it on the flex....
Old Mar 22, 2005 | 03:18 PM
Francesco's Avatar
only certain cars have the ability to use the edfc with ra's, and the other tein coilovers....but for the s2000, you can only use it on the flex....</TD></TR></TABLE>
s2000 is a bitch for the edfc. their is no room to spare at all in the trunk for the rear motors.
Old Mar 22, 2005 | 04:57 PM
papa5murf's Avatar
s2000 is a bitch for the edfc. their is no room to spare at all in the trunk for the rear motors.</TD></TR></TABLE>
passenger side is fine... but the drivers side is a biotch.... i undid the gas tubes and moved them out of the way to get in there... and i think there's barely enough clearance...
Old Mar 22, 2005 | 06:13 PM
Francesco's Avatar
i took that strut brace off and squeezed my hands in there...
Old Mar 22, 2005 | 06:21 PM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">i took that strut brace off and squeezed my hands in there...</TD></TR></TABLE>
yeah i took that off too
Old Mar 22, 2005 | 06:41 PM
Francesco's Avatar
hardest part was getting those gold hex screws in the rears
Old Mar 24, 2005 | 05:12 AM
JJFreshy's Avatar
Any tips on tightening down the top nut. With the stock shock you can use an allen wrench to keep the rod from spinning, do you need some other special tool for the tien flex's? The instructions say to be sure it is tight, it feels tight but want to be sure.
