Honda S2000 Honda S2000
Tapping noise
Old Sep 25, 2008 | 04:22 AM
MD06LBP's Avatar
Default Tapping noise
Back in June I was in VTEC for a bit of an extended period, and after that my engine started a tapping noise. Didn't have time to do a whole lot with it, as I was leaving for Iraq. It got pretty loud at times. Didn't misshift at all. I'm on my second S, this one's a MY00 and as far as I know, has not had the banjo bolts replaced. Didn't realize how important it was. After reading about it, my guess is scoring on the cylinder wall.
It wasn't throwing a CEL, but it's pretty loud and it taps faster as I increase throttle, if that makes sense. I checked the oil level after it happened, was a bit low but nothing catastrophic. Changed the oil out completely just to see if that would fix it, it didn't. I don't really know any mechanics in the El Paso area, I just PCSed there a couple months before deploying.
I'll be getting back in a month or so, so I'm going to look into the problem. I should look for blackening of the spark plugs due to incomplete combustion, correct? My backup ideas are timing chain tensioner and valve adjustment, but it really is pretty loud, and it happened after an extended period of hard use (not a misshift). I'll try and take a video after I get back so you can hear it. This would be able to be resleeved, correct? Or would I be better off getting a new block? My S isn't absolute necessary, and I've wanted to take apart an F20C for a while now, so if I have to do that, so be it. Just want some advice on what educated people would guess.
Old Sep 25, 2008 | 05:36 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: Tapping noise (MD06LBP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MD06LBP &raquo;</TD></TR><TR><TD CLASS="quote"> My backup ideas are timing chain tensioner and valve adjustment.</TD></TR></TABLE>
Could very well be it... how many miles on the car... did you ever replace the TCT or adjust the valves??? ohhh id def check your valve retainers as well... a lot of people have cracked ones and dont even know it... upgrade to the AP2's...
Old Sep 25, 2008 | 03:14 PM
MD06LBP's Avatar
There's 64k miles on the car. I've had it since January, 61k miles when I got it. I don't drive it that often, plus I've been gone. I do not know if the TCT was ever replaced or valves were ever adjusted. I purchased it from a woman whose husband owned it (he died).
Old Sep 25, 2008 | 03:48 PM
papa5murf's Avatar
It could honestly be a variety of different things. Need more info.
Old Sep 25, 2008 | 03:52 PM
K2MotorPhilip's Avatar
Possibly TCT ?
Old Sep 25, 2008 | 04:02 PM
MD06LBP's Avatar
Default Re: Tapping noise (papa5murf)
Wish I could give you more info. I don't really have access to the car right now, I'm just trying to get ready so I can get this fixed ASAP after I get back. And when'd you move to London? (former member of s2ki mid-a)
Old Sep 25, 2008 | 04:16 PM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MD06LBP &raquo;</TD></TR><TR><TD CLASS="quote">Wish I could give you more info. I don't really have access to the car right now, I'm just trying to get ready so I can get this fixed ASAP after I get back. And when'd you move to London? (former member of s2ki mid-a)</TD></TR></TABLE>
Came over on the 26th of August.
How long as it been ticking for? Does it only get louder and louder when you get on the gas? How many miles have you driven the car since the ticking started? (if it's been a few miles, have you noticed any extra burning of fuel? or do you see any oil residue on the block anywhere?
Old Sep 25, 2008 | 04:59 PM
MD06LBP's Avatar
It started about 2 weeks before I left, so early June. It hasn't been driven since mid-June. It ticks faster when I'm on the gas. Not so much louder. Definitely more noticeable when I have the top up. Miles since it started? Probably no more than 100-200. It started right before I deployed. Haven't noticed any extra burning of fuel, and I never looked for oil residue. I'll see if I can call someone back home and have them take a quick look at it.
Old Sep 25, 2008 | 06:39 PM
mingus's Avatar
Default Re: (MD06LBP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MD06LBP &raquo;</TD></TR><TR><TD CLASS="quote">I purchased it from a woman whose husband owned it (he died).</TD></TR></TABLE>
I saw this in an episode of Scooby Doo.
Old Sep 25, 2008 | 06:54 PM
bigmacnfries's Avatar
Default Re: (mingus)
^^^^ pesky kid
Old Sep 29, 2008 | 08:20 AM
s2k5's Avatar
if your gona replace your block that might be your best options&lt; if not t hen id say just adjust your valves. im guessing your over reving the hellout of your car?
thephilosopher
Transmission & Drivetrain
May 30, 2013 03:13 PM
94XJ4Door
Honda Civic (2001 - 2005)
Apr 7, 2013 11:15 AM
vicd_teg
Mar 22, 2007 09:24 PM
JmurGSR98
Apr 5, 2006 06:20 PM
da9pwnsu
Dec 7, 2005 07:32 PM
