Honda S2000 Honda S2000
tachometer problem!!
Old Dec 28, 2005 | 06:09 PM
seungjae012's Avatar
Default tachometer problem!!
I'm currently about to boost and am trying to install a tachometer...problem is, s2000 don't have distributor... where and how can i find the wires to connect the wires from the apexi tachometer? please help!!
Old Dec 28, 2005 | 06:13 PM
revvin9k's Avatar
Default Re: tachometer problem!! (seungjae012)
May I be the first to ask what you need a tach for? Is the S2000 tach not readable enough?
Old Dec 28, 2005 | 06:19 PM
Default Re: tachometer problem!! (revvin9k)
i talked to the mechanics who dyno the s2000 and they said that the digital tach cannot keep up with the motor. so i should install a tach.... any ideas how to find the wire for the tach?>
Old Dec 28, 2005 | 10:10 PM
Mr. Projekt's Avatar
* B A N N E D *
ECU based DCI.
Old Dec 29, 2005 | 05:43 AM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seungjae012 &raquo;</TD></TR><TR><TD CLASS="quote">i talked to the mechanics who dyno the s2000 and they said that the digital tach cannot keep up with the motor. so i should install a tach.... any ideas how to find the wire for the tach?&gt;</TD></TR></TABLE>
ROFFL ... people will believe anything these days...
Old Dec 29, 2005 | 05:44 AM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revvin9k &raquo;</TD></TR><TR><TD CLASS="quote">May I be the first to ask what you need a tach for? Is the S2000 tach not readable enough?</TD></TR></TABLE>
cuase he's a ricer....
Old Dec 29, 2005 | 08:18 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
That sounds rediculous. There are lots of boosted S2Ks running only the factory tach with no problems.
Old Dec 29, 2005 | 10:25 AM
* B A N N E D *
If I was your mechanic i'd charge you for a power steering pulley converter.
Old Dec 29, 2005 | 10:33 AM
papa5murf's Avatar
Default Re: tachometer problem!! (Slideways2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slideways2000 &raquo;</TD></TR><TR><TD CLASS="quote">If I was your mechanic i'd charge you for a power steering pulley converter.</TD></TR></TABLE>
and blinker fluid
maxpierre
Honda S2000
13
Dec 11, 2006 09:14 PM
mrdeadman
Aug 4, 2005 11:01 AM
onboost
Dec 15, 2004 09:12 AM
DeepSpeed02SI
Sep 30, 2003 08:12 AM
vw_ev
Dec 1, 2002 03:36 PM
