Honda S2000 Honda S2000
Stock Diff or Not?
Old Nov 14, 2004 | 10:19 AM
92jdmhatch's Avatar
Default Stock Diff or Not?
I had my friends dad find me a s2000 from the auctions...it is a clean title 2000 wih 28k miles on there well i bearly hit 30....but how would i know the guy who owned it changed the rear diff or not because....i have a feeling he did because he had 19inch wheels he had the full exaust tein ra's and like the aem v2..all of which is irrelevant to a diff however i am thinkin he put good money into the parts and with 19'z someone would consider looking into a rear diff as well...soo what would be the best way to find out....?
Old Nov 14, 2004 | 01:17 PM
evil vapor's Avatar
Default Re: Stock Diff or Not? (92jdmhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92jdmhatch &raquo;</TD></TR><TR><TD CLASS="quote">I had my friends dad find me a s2000 from the auctions...it is a clean title 2000 wih 28k miles on there well i bearly hit 30....but how would i know the guy who owned it changed the rear diff or not because....i have a feeling he did because he had 19inch wheels he had the full exaust tein ra's and like the aem v2..all of which is irrelevant to a diff however i am thinkin he put good money into the parts and with 19'z someone would consider looking into a rear diff as well...soo what would be the best way to find out....?</TD></TR></TABLE>
there's no easier way to find out other than jacking up the car and seeing if the factory marks (yellow) on the fill plug match/line up with the mark on the case. That will only tell you the fill plug was once removed but wont tell you when the fluid was replaced. Have it replaced if you don't have service records from the previous owner. This is common knowledge when buying a used car, no service records=inspecting and replacing regular service items.
Old Nov 14, 2004 | 01:20 PM
92jdmhatch's Avatar
Default Re: Stock Diff or Not? (vapor)
no no i dont mean whether the fluid was changed i want to know if he changed it to like a comptech or cusco or something else....
Old Nov 14, 2004 | 01:25 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92jdmhatch &raquo;</TD></TR><TR><TD CLASS="quote">no no i dont mean whether the fluid was changed i want to know if he changed it to like a comptech or cusco or something else....</TD></TR></TABLE>
you need to tear down the assembly
Old Nov 14, 2004 | 02:20 PM
92jdmhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">
you need to tear down the assembly</TD></TR></TABLE>
is that something i can do myself...what about the housing....by looking at it...is it possible to tell whether its stock or not?
Old Nov 14, 2004 | 03:00 PM
WowOzYouRock's Avatar
you cant tell by just looking at the assembly ... unless you have an x-ray eyes
Old Nov 14, 2004 | 03:16 PM
92jdmhatch's Avatar
Default Re: Stock Diff or Not? (Y2K_S2K)
so basically i wont be able to tell unless i open stuff up......now how much different does it look from a stcok one of it is changed because i got someone who will open it up for me but how would i know
Old Nov 14, 2004 | 03:18 PM
cmdr430's Avatar
is there something wrong with it?
Old Nov 14, 2004 | 03:46 PM
92jdmhatch's Avatar
Default Re: Stock Diff or Not? (cmdr430)
no but i drive aggresively...popping the clutch..and i want to launch it and i am afraid of messing it up and getting stuck somewhere and the person before could have not changed it and put stress on it soo might not be able to hold much longer...soo i just want to change it to be on the safe side.
Old Nov 14, 2004 | 07:12 PM
just look at them bolts on the assembly itself ... if it looks untouched then its stock
diff ... or go to ur local dealership and let them check it out for you ...
Old Nov 14, 2004 | 11:56 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92jdmhatch &raquo;</TD></TR><TR><TD CLASS="quote">no but i drive aggresively...popping the clutch..and i want to launch it and i am afraid of messing it up and getting stuck somewhere and the person before could have not changed it and put stress on it soo might not be able to hold much longer...soo i just want to change it to be on the safe side.</TD></TR></TABLE>
what about other parts of the car? You will waste time/money by tearing down a working assembly. You'll get some warning noises before it lets go unless you launch the car at 7krpms on a normal basis.
If you have a friend that wants to open it up to see what's inside, you'll want to hope he knows what he's doing. Taking the diff assembly in and out of the car isn't as easy as changing spark plugs.
Old Nov 15, 2004 | 12:58 AM
Raymund's Avatar
New User
There's usually more than one reason why a person will change something. For the diff, a change in final drive is one. Check if your top speed in 1st or 2nd jives with the handbook located in the glove box. This alone won't tell you if it has been reinforced or not.
Good luck. Drop the clutch and hope for the best.
Old Nov 15, 2004 | 08:15 AM
92jdmhatch's Avatar
Default Re: Stock Diff or Not? (Raymund)
never came with a handbook......i have dropped the clutch many times...however i do not drive the car every day and drop the clutch everyday maybe once or twice every weekend
racin jasin R
Feb 15, 2011 06:44 AM
J's_Racing
Honda S2000
13
Mar 29, 2007 10:13 AM
Will_ChinLee
Mar 20, 2006 09:45 AM
SMSP
Honda S2000
Feb 7, 2005 10:03 AM
cmdr430
Jan 1, 2005 06:00 PM
