Honda S2000 Honda S2000
Stereo removal...?
Old Sep 18, 2006 | 12:10 PM
Htounndea's Avatar
Default Stereo removal...?
Has anybody here removed there stereo in their S2000? If you have, where are bolt i need to remove.....?
Old Sep 18, 2006 | 01:17 PM
nuttybumpo's Avatar
Default Re: Stereo removal...? (Htounndea)
super easy
pry the door off and there is two screws
Old Sep 18, 2006 | 05:47 PM
revhi's Avatar
4 screws
Old Sep 18, 2006 | 11:58 PM
JimDCXC's Avatar
Old Sep 19, 2006 | 05:47 AM
JDM knowledge's Avatar
Default Re: (revhi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhi &raquo;</TD></TR><TR><TD CLASS="quote">4 screws</TD></TR></TABLE>
Old Sep 19, 2006 | 12:29 PM
Htounndea's Avatar
Where are the screws......?
Old Sep 19, 2006 | 12:44 PM
cybergreencivic's Avatar
Default Re: (Htounndea)
Your radio is in here (below)
http://www.hondaautomotivepart...RNISH
The four bolts are the ones on the side once you take the big plastic piece that sits around your radio off(below)
http://www.hondaautomotivepart...RADIO
JimDCXC i have a stock radio. i PM'd you about it.
Old Sep 19, 2006 | 05:33 PM
revhi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Htounndea &raquo;</TD></TR><TR><TD CLASS="quote">Where are the screws......?</TD></TR></TABLE>
If you have to ask, you shoudnt be doing it.
Old Sep 19, 2006 | 07:15 PM
Htounndea's Avatar
Default Re: (revhi)
it isnt my car and ive done stereos.....
Old Sep 21, 2006 | 04:15 PM
CHILIBEANZ's Avatar
dont' pry at the outside plastic. pull by the radio door at a 45 degree angle it should pop right off. then u will see the screws.
Old Sep 21, 2006 | 08:13 PM
K20 PWR's Avatar
use a flat head to help with leverage when taking off the radio door cover. then 2 screws are on each side, take them out and pull the headunit out and unplug. Make sure you have the code if you want to re-use it again.
daveng
Acura TL, RL & ZDX
Jul 6, 2007 02:20 PM
accord06
Sep 3, 2006 01:17 PM
greaseball
Dec 28, 2004 09:18 PM
OneFire
Nov 18, 2004 06:11 AM
Flux
Aug 2, 2002 11:51 AM
