Honda S2000 Honda S2000
spoon throttle body??
Old Dec 13, 2006 | 04:39 PM
HondaPH22's Avatar
Default spoon throttle body??
any info on the spoon or other makes of TB's for the s2k spoon states about an 8hp gain? Worth the money or a waste????
Old Dec 13, 2006 | 11:19 PM
Francesco's Avatar
Default Re: spoon throttle body?? (HondaPH22)
whats your other mods to support this?
Old Dec 13, 2006 | 11:34 PM
kane.s2k's Avatar
waste...TB doesn't gain much even with port matching. Also the spoon only tapers the TB really. It is so far before the ports it wont even do anything noticable for the overall velocity going into the engine.
Old Dec 14, 2006 | 09:10 AM
Mr. Projekt's Avatar
* B A N N E D *
That thing sucks...
a lot of air. It whistles Throttle response is nuts. Solid midrange. Worth it.
I'd have to disagree a little kane. The only thing I had to match was the gasket. The IM matched up to the 66mm just right.
Old Dec 14, 2006 | 09:40 AM
kane.s2k's Avatar
I should have made them seperate paragraphs. I meant most TB's don't gain anything without port matching. The spoon is just a tapered TB it doesn't actually increase the inlet diameter. The taper is there to try and increase the air velocity for response purposes mainly. The HP gains wouldn't be substantial.
Old Dec 14, 2006 | 10:28 AM
* B A N N E D *
Default Re: (kane.s2k)
Even tapered, it goes from 70 to 66mm vs. the stock 62. 10% increase in area does wonders for response.
Old Dec 14, 2006 | 12:50 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (FR-MOB: Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Even tapered, it goes from 70 to 66mm vs. the stock 62. 10% increase in area does wonders for response.</TD></TR></TABLE>
took the w3rdz out my mouf
Old Dec 14, 2006 | 01:09 PM
kane.s2k's Avatar
You can press the gas 10% more and see what that does for response
Old Dec 14, 2006 | 01:15 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kane.s2k &raquo;</TD></TR><TR><TD CLASS="quote">You can press the gas 10% more and see what that does for response </TD></TR></TABLE>
not with these prices...
Old Dec 14, 2006 | 02:26 PM
* B A N N E D *
But my WOT is 110% of your WOT.
AllmotaB18EH2
12
Feb 15, 2005 11:56 PM
"SPOON EG"
Jul 26, 2002 11:25 AM
IntegraT
Dec 18, 2001 09:42 AM
ic108
Nov 22, 2001 06:55 AM
ITR111
Aug 24, 2001 07:03 AM
