Honda S2000 Honda S2000
size of my...
Old Oct 17, 2005 | 12:50 PM
SwpR's Avatar
Default size of my...
hey guys, would 245 45 on the stock rims be ok? since this is the correct size unles its the so2's? btw, my car is SLAMMMMMMMED! no finger gap no nothing. so would this be ok whne it comes to rubbing issues or anything else?
Old Oct 17, 2005 | 12:56 PM
WowOzYouRock's Avatar
Default Re: size of my... (SwpR)
Old Oct 17, 2005 | 01:12 PM
Mr. Projekt's Avatar
* B A N N E D *
You're not going to find any other different sizes on 245/16s. Make sure you run 50 series front tires though.
Old Oct 17, 2005 | 01:37 PM
Nishant's Avatar
Default Re: size of my... (Sideways2000)
as long as this is the rear tire, yes. Just run a lil neg camber in the rear. Now if this is for up front, then its very bad
Old Oct 17, 2005 | 04:46 PM
SwpR's Avatar
Default Re: size of my... (Nishant)
the front should be 205 55 16 with 245 45 16 correct? on a slammed car, it shoudl be good w/out any problems?
Old Oct 17, 2005 | 04:57 PM
User Name's Avatar
Yes
Old Oct 17, 2005 | 05:25 PM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwpR &raquo;</TD></TR><TR><TD CLASS="quote">the front should be 205 55 16 with 245 45 16 correct? on a slammed car, it shoudl be good w/out any problems?</TD></TR></TABLE>
shouldn't have any problems, those are oem s02 equivalent sizes
Old Oct 17, 2005 | 10:01 PM
SwpR's Avatar
oh ok! thasnk a lot guys! appreciate it.
Old Oct 18, 2005 | 02:59 PM
o2silverS2k's Avatar
So on my 02 stock 16 inch wheels I can fit 245/50/16 on the rear??
I didn't think you could go any wider than 235 in the rear. Thanks for any help.
Old Oct 18, 2005 | 04:56 PM
Nishant's Avatar
Default Re: size of my... (o2silverS2k)
the oem S02 tire that says its 225 wide is wrong. if you measure it, its 245. That why when you buy other tires, you must buy a 245/45/16. If not, you are buying the wrong size and will have snap oversteer
Old Oct 18, 2005 | 07:47 PM
SwpR's Avatar
is the 245 compared to teh 225 so2's the exact same size as far as teh thickness of it? or does the 245 look bigger? i hope bigger as i like the tires wider in teh back.
Old Oct 18, 2005 | 07:55 PM
kuja's Avatar
from what nishant said i'm assuming they would be the same width.
Old Oct 18, 2005 | 08:01 PM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwpR &raquo;</TD></TR><TR><TD CLASS="quote">is the 245 compared to teh 225 so2's the exact same size as far as teh thickness of it? or does the 245 look bigger? i hope bigger as i like the tires wider in teh back.</TD></TR></TABLE>
s02 rear is 225/50/16....any other tire 245/45/16 both are the same when measured
Old Oct 19, 2005 | 01:16 AM
SwpR's Avatar
aww burn. loll
Agent Zero
Honda S2000
27
Mar 20, 2007 03:32 AM
ejcivicdee
Jun 2, 2006 06:16 PM
import_love
Honda S2000
12
May 25, 2006 01:50 PM
2000gsrsedan
Mar 28, 2003 05:18 AM
HondaIntegraLS
Jun 27, 2001 07:43 PM
