Honda S2000 Honda S2000
S2000 softtop
Old Sep 19, 2005 | 05:22 AM
freeagent32's Avatar
Default S2000 softtop
I'm in the process of getting a 2001 sk2. The back window of the softtop looks real shitty, is real small compare to some other ones I seen. Can anyone help???
Old Sep 19, 2005 | 05:52 AM
Nishant's Avatar
Default Re: S2000 softtop (freeagent32)
00-01's have a plastic rear window which if not taken care of properly over time will become blurry.
02+ have a glass rear window which you will prob like much better
Old Sep 19, 2005 | 12:15 PM
b e b's Avatar
Default Re: S2000 softtop (Honda S2000)
I think your only option is to replace it.
freeagent--if you switch to the glass rear window--keep in mind its smaller than the plastic ones.
Old Sep 19, 2005 | 12:27 PM
p nut's Avatar
You can just get the plastic window, but it's pricey and install is a PITA, or so I've heard.
Old Sep 19, 2005 | 12:30 PM
b e b's Avatar
I dont have plastic, so I dont know....... But from what Ive heard--the whole softtop has to be replaced.........
Either hardtopguy or s2ki marketplace sells them for like $850 for the one with glass I believe....
http://www.hardtopguy.com/stor...age=1
Old Sep 19, 2005 | 12:41 PM
p nut's Avatar
No, you do NOT have to replace the whole top. The window zips out at the top and the sides, but the bottom part is riveted in. It's a PITA to take out. If you take it to a dealer, it'll take them the whole day, usually.
Old Sep 19, 2005 | 12:56 PM
p nut's Avatar
No. Just a leg and some fingers.
I've heard anything from $0 - $500. Depends on the dealer. If you're still under warranty, I believe it's free. There's a TSB on it, too.
Old Sep 19, 2005 | 01:59 PM
Luder94's Avatar
Default Re: (P Nut)
A blurry plastic window can be recovered to crystal clear with a little bit of elbow grease.
Search over at S2Ki.com for the how-to. It should cost no more than $15 in materials, and 1-2 hours of your time.
Old Sep 20, 2005 | 01:08 AM
dave22's Avatar
Default Re: (P Nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut &raquo;</TD></TR><TR><TD CLASS="quote">No, you do NOT have to replace the whole top. The window zips out at the top and the sides, but the bottom part is riveted in. It's a PITA to take out. If you take it to a dealer, it'll take them the whole day, usually.</TD></TR></TABLE>
You DO have to take out the whole top. The glass window WILL NOT fit in an '00-'01 top.
I've got an '04 top in my '01. I managed to find a deal on a lightly used one on s2ki. The swap is very extensive, requiring the removal of just about every interior panel aft of the dashboard. And some custom straps will need to be made. A search on s2ki should give you the answers you need.
If I could do it again, I'd just replace the entire frame and top together.
Old Sep 21, 2005 | 05:30 AM
I think I would rather replace the window instead of the softtop. For the kind of money mind as well get the hardtop.
Old Sep 21, 2005 | 03:28 PM
Luke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda S2000 &raquo;</TD></TR><TR><TD CLASS="quote">How do i make my rear window unblurry? </TD></TR></TABLE>
Goto a bmw dealer and buy their plastic widow cleaner, it is the best thing to clean them up. Also it is possible to fit a glass rear, will post a link or search on the web yourself for it.
Old Sep 27, 2005 | 08:36 AM
s2k04's Avatar
do you know how much the bmw plastic cleaner costs? thanks
imsebtactular
Honda S2000
Jan 22, 2010 07:34 PM
B18CJDM ITR
Honda S2000
12
May 7, 2007 10:50 AM
eLeCtRoNSi00
Honda S2000
15
Feb 6, 2006 05:40 AM
1zach4
Honda S2000
15
Apr 10, 2005 09:00 PM
Speed2K
Honda S2000
Jul 12, 2001 02:13 PM
