Honda S2000 Honda S2000
s2000 hids
Old Mar 25, 2015 | 06:16 AM
mario6712's Avatar
Default s2000 hids
My passenger side hid tends to flicker they are the oem hids just wondering what it could be the connections are good and have good contact any help of what i should start looking in to buy to fix it before it goes out
Old Mar 26, 2015 | 06:04 AM
Tight-R's Avatar
Default Re: s2000 hids
Does it flicker on and off, or is it bouncing?
Old Mar 30, 2015 | 06:29 AM
mario6712's Avatar
It flickers on and off then sometimes it will just turn off
Old Apr 7, 2015 | 11:57 AM
White Smoke's Avatar
i my honda
Global Mod
Have you inspected the igniter to make sure it has a good connection?
Old Apr 17, 2015 | 08:27 AM
FDNewbie's Avatar
I'd definitely check the connections first. If they're all good, a simple trick is to swap the ballasts and see if the problem now appears on the opposite side. If so, now you know the ballast is bad.
Old Apr 17, 2015 | 09:56 AM
c-rex23's Avatar
If you do need new bulbs, I have a good pair from my headlights I removed when swapping in ap2 headlights.
Old Apr 21, 2015 | 01:37 PM
mario6712's Avatar
I check it out try that see it it works s2k is chillin on jack stands at the moment and i havent had a chance to really get after it work has been crazy gonna swap out all the bushings
06civicoolie
Honda Civic (2006 - 2015)
Dec 7, 2007 08:07 PM
pnoi_01dc2r
Dec 28, 2005 03:32 PM
EFFECT
Dec 10, 2003 11:44 AM
FritzInTN
Feb 7, 2003 11:05 AM
