Honda S2000 Honda S2000
S2000 DROP
Old Mar 28, 2003 | 01:33 PM
2camsaam's Avatar
Default S2000 DROP
I have 18" rims. I want to lower my car.
What drop should I go w/ to give the most tuck w/o scrubing, w/o having to replace struts or having bounce?
Front: 225/40/18
Rear: 255/35/18
Just so I don't get flamed for having 18s, they are VOLK GTNs.
Old Mar 28, 2003 | 09:58 PM
Blue-Civic-Hybrid's Avatar
Loved
Default Re: S2000 DROP (2camsaam)
Try a 1'inch drop with some Ground Control coilovers for the S2000....
or some Comptech springs...
or some KGMM springs....
or some Nuespeed springs...
or some Teins coilovers....
get the picture?
[Modified by Blue-Civic-Hybrid, 7:02 AM 3/29/2003]
Old Mar 28, 2003 | 10:10 PM
Reid's Avatar
Global Moderator
Get shocks with a greatly decreased droop travel and you won't have problems with the car being overly bouncing. Also run lots of camber to keep the top of the tire from hitting the fender.
Don't worry about getting flamed. It's your car, and as long as you like it, that's all that matters.
Besides, 18s are 18s, it does not matter if they're made by Niche or Volk. Oversized wheels will kill performance regardless of brand or weight.
Old Mar 29, 2003 | 12:41 AM
PROFILES2000's Avatar
Default Re: S2000 DROP (Reid)
right now i have Tanabe Sustec GF210 springs on my car now with the stock struts. the ride quality is great and its only a 1.5 inch drop i dont think rubbing will be much of a problem
you can find pix at https://honda-tech.com/zerothread?id=446774
the pix at the bottom
Old Mar 29, 2003 | 07:59 AM
StormBringer's Avatar
Default Re: S2000 DROP (PROFILES2000)
Just remeber that depending on your rims and your tires and what you like to run as your aligment might have rubbing problems. That being said also remeber that if you drop the car more then 1 inch you will have preoblems getting the car back into the stock suspension settings.
Old Mar 29, 2003 | 09:35 AM
2camsaam's Avatar
Default Re: S2000 DROP (StormBringer)
Please elaborate on this. Do you mean getting the car back to stock suspension settings once its lowered, or do you mean if I decided to put the stock suspension back on the car it would provide me with problems.
Also, what kind of problems do you for see?
Old Apr 2, 2003 | 03:16 AM
2camsaam's Avatar
bump, please answer my question somebody.
Old Apr 2, 2003 | 08:42 AM
Hatchimon's Avatar
I have a set of GF210's with 18" OZ no rub about 1.5" drop. Ride is much different from factory due to no linear springs. Oem comes with linear springs and most aftermarket springs are progressive. Hope that helps. Like I said no rubbing.
Old Apr 2, 2003 | 09:04 PM
Evo s2000's Avatar
Default Re: S2000 DROP (Hatchimon)
If you are interested. I carry both the Tanabe NF and the GF. 1.5 inch drop and similar spring rate to the factory. Give me a call.
Jeff - Evolution
703.961.9090
Old Apr 3, 2003 | 09:15 AM
s2kwhite's Avatar
Default Re: S2000 DROP (Evo s2000)
I got 18 also with neuspeed springs and i have no rubbing but i cambered my wheels to compensate. You can check pics if you like here.
https://honda-tech.com/zerothread?id=461134
Old Apr 5, 2003 | 06:55 PM
2camsaam's Avatar
Default Re: S2000 DROP (s2kwhite)
what kind of camber kit did you go with?
I have been looking for one, however, I don't know of any companies making them for the s2000.
Also, is your car bouncy with the lowering spring and stock shocks? How does it handle compared to stock, please be honest.
dalilenginedatcud
Jul 17, 2007 12:59 PM
hondawill
Honda S2000
12
Jun 5, 2006 08:58 PM
BassBoy19
Honda S2000
19
Mar 11, 2004 07:12 AM
Civichatch2k
Honda S2000
26
Dec 12, 2003 01:27 PM
