Honda S2000 Honda S2000
S2000 cluster?
Old Feb 11, 2006 | 06:12 PM
EGmmBAH's Avatar
Default S2000 cluster?
I was wondering if anyone had the pinouts for a 2002 S2000 gauge cluster?
Old Feb 16, 2006 | 04:13 PM
DC2user's Avatar
Default Re: S2000 cluster? (EGmmBAH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kazino42 &raquo;</TD></TR><TR><TD CLASS="quote">I just got my S2000 cluster installed and looks great. Here's a pinout I did for my 2001 cluster.
Connector A ----------------------------------------------- EG harness
1 BLU/RED (Seat belt reminder) --------------------------10 BLU/WHT (10 pins connector)
4 PNK (SRS)
6 YEL (Fuse 5) ----------------------------------------------10 BLK/YEL (12 pins connector)
7 GRN/RED (Left turn signal (+)) --------------------------4 GRN/BLU (12 pins connector)
8 GRN/YEL (Right turn signal (+))-------------------------3 GRN/BLU (12 pins connector)
9 RED/WHT (High beam (+)) ------------------------------1 RED/GRN (10 pins connector)
10 RED/BLU (High beam (-)) -------------------------------6 BLK (10 pins connector)
11 BLU/BLK (Trunk indicator) ------------------------------9 GRN (10 pins connector)
Connector B
2 RED/YEL (Fuse 45) --------------------------------------10 BLK/YEL (12 pins connector)
3 RED/BLK (Circuit 11 – dash and console lights (+)) --10 BLK/YEL (12 pins connector)
4 YEL (Fuse 5) ----------------------------------------------10 BLK/YEL (12 pins connector)
5 WHT/RED (Fuse 25) -------------------------------------10 BLK/YEL (12 pins connector)
8 BLK (Ground) ----------------------------------------------6 BLK (10 pins connector)
9 BLK (Ground) ----------------------------------------------6 BLK (10 pins connector)
10 RED (Circuit 12 – dash and console lights (-)) --------6 BLK (10 pins connector)
Connector C
3 BLU/WHT (Vehicle speed signal input (-)) ----------------2 YEL/BLU (12 pins connector)
5 BLU (RPM signal input) -------------------------------------8 BLU (12 pins connector)
7 YEL/GRN (Coolant temp input) ----------------------------7 YEL/GRN (10 pins connector)
8 YEL/BLK (Fuel gauge signal input) -------------------------1 YEL/WHT (12 pins connector)
15 BLU/YEL (Cruise control indicator (-)) -------------------3 --- (10 pins connector)
Connector D
8 BLU/RED (ABS indicator input)
9 GRN/WHT (E-brake indicator) ------------------------------2 GRN/RED (10 pins connector)
11 WHT/BLU (Charging system indicator (-)) --------------5 WHT/BLU (12 pins connector)
12 BLK/YEL (Fuse 6) -----------------------------------------10 BLK/YEL (12 pins connector)
13 YEL/RED (Engine oil pressure switch input (-)) ---------6 YEL/RED (12 pins connector)
14 GRN/ORN (Malfunction indicator light (-)) ---------------5 GRN/ORG (10 pins connector)
16 WHT/RED (Fuse 25) --------------------------------------10 BLK/YEL (12 pins connector)
Tuned with CROMEPRO
LS/Vtec 463hp/312torque Stock Sleeve https://honda-tech.com/zerothread?id=1253381
New set-up, sleeved B18c 11.07 @ 114mph https://honda-tech.com/zerothread?id=1369510
Old Feb 16, 2006 | 08:21 PM
veut's Avatar
Default Re: S2000 cluster? (DC2user)
Its work?????
Old Feb 18, 2006 | 09:41 PM
liam821's Avatar
Default Re: S2000 cluster? (veut)
I dont think the speedo works in eg/ef/dc...because the VSS works different.
liam
Old Feb 19, 2006 | 06:41 AM
veut's Avatar
Default Re: S2000 cluster? (liam821)
http://a.photofile.ru/image.ph...ger=4
Its Ok))))) EK4..))) but only 1 problem.,.,.7 YEL/GRN (Coolant temp input) ----------------------------7 YEL/GRN (10 pins connector)
Spankedrican92
Oct 18, 2013 07:47 PM
The G2 Racer
Canada (Sales)
Aug 21, 2008 07:21 PM
redsolturbo
Dec 12, 2007 12:41 PM
11secteg
Jan 6, 2007 06:02 PM
raceready_vtec
Honda S2000
Oct 16, 2006 10:50 AM
