s2000 camber kit ??
you can only adjust it so much....when I had my coilovers I was running -3.5 on the rear and that was maxed out. On my skunk2's i think im still -3 or-2.5 which I believe is still more then stock. So in some cases a camber kit is required. I dont think there are to many options I know Eibach makes a kit, but I know if you buy a kit you have to run 17" wheels or bigger
ive seen guys running 5 degrees of camber on their stock setups with just coilovers, so i dont see why you would need a camber kit then.
im currently running 3.5 degrees in the rear, and the shop that did my allignment said that they could have gone another 1-1.5 degrees
you can only adjust it so much....when I had my coilovers I was running -3.5 on the rear and that was maxed out. On my skunk2's i think im still -3 or-2.5 which I believe is still more then stock. So in some cases a camber kit is required. I dont think there are to many options but I know if you buy a kit you have to run 17" wheels or bigger
Buying a set of camber kits is a complete waste of money.
And you should take your car to a better alignment place, because there is no reason why you have to be running -3.5 on Skunk2 springs. And -2.5 is what many people run who are slammed.
-SPC makes caber kit for s2k
the problem with stock camber adjustment in the front is that the more negative camber you use, you reduce caster. so i'm going to use this kit to keep max caster and still be able to get -3 deg camber that i need for track.
http://cgi.ebay.com/ebaymotors/SPC-H...QQcmdZViewItem
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
lol jk its a quote from the intial d movie
manson
Apr 23, 2004 09:44 AM
