Honda S2000 Honda S2000
Replacing the Fuel Pump
Old Jun 27, 2008 | 06:19 AM
MADBADGER's Avatar
Default Replacing the Fuel Pump
What is the easiest way to get to the fuel pump to replace it? im going turbo
Old Jun 27, 2008 | 06:42 AM
papa5murf's Avatar
Default Re: Replacing the Fuel Pump (MADBADGER)
Half of it through the trunk, the other half through the cabin itself. It's a bit of a pain.
Old Jun 27, 2008 | 08:22 PM
stealthdc2's Avatar
Default Re: Replacing the Fuel Pump (papa5murf)
i did the whole process inside the car. but i don't have a softtop so i don't know if that would make too big a difference. i recommend having a lot of rags nearby so you don't get fuel in the interior.
Old Jun 28, 2008 | 04:44 AM
HondaKyle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MADBADGER &raquo;</TD></TR><TR><TD CLASS="quote">What is the easiest way to get to the fuel pump to replace it? im going turbo</TD></TR></TABLE> what pump did you get?
Old Jun 28, 2008 | 05:37 AM
papa5murf's Avatar
Default Re: Replacing the Fuel Pump (stealthdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthdc2 &raquo;</TD></TR><TR><TD CLASS="quote">i did the whole process inside the car. but i don't have a softtop so i don't know if that would make too big a difference. i recommend having a lot of rags nearby so you don't get fuel in the interior. </TD></TR></TABLE>
Very big difference is you don't have a softtop. Make the job a hell of a lot easier.
Old Jun 28, 2008 | 07:10 AM
joey1320's Avatar
i will suggest removing the schrader(?) valve on the fuel rail to remove the pressure.(do s2k's got one?) or you can remove the fuel pump fuse and run the car until it dies but then you run the risk of runin lean, even tho is only idling
Old Jun 28, 2008 | 02:31 PM
MADBADGER's Avatar
i just popped out the spare, and the piece of plastic the soft top sits into and worked it out that way. took me about 45 minutes all together, really easier than what it seamed.
datonefoo1
Feb 5, 2008 06:46 PM
beef-cake
Feb 26, 2007 08:16 PM
SiR99
Aug 25, 2006 08:42 AM
90si_mugen_crx
Apr 11, 2005 01:07 AM
BoostedsiR
Mar 9, 2004 09:05 AM
