Honda S2000 Honda S2000
Radio trouble, help please.
Old Jun 1, 2009 | 01:31 PM
ryan8624's Avatar
Default Radio trouble, help please.
My radio in my 2000 S2k just simply stopped working today. I get nothing on the screen at all, only the red anti-theft light flashes. I have tried the radio code, and checked the fuses. Right now I have the battery unhooked hoping to reset it, if not Honda said its most likely radio failure. Here is my question. Has anyone else experienced this? if so please share you insight, second; if I replace my radio, will an aftermarket one worth with the dashboard controls? I can get one cheaper from best-buy then Honda, but I prefeere OEM and I want my dash board controls. Thank in advance.
Old Jun 1, 2009 | 01:40 PM
dc4-b20's Avatar
Default Re: Radio trouble, help please.
did you battery die?
Old Jun 1, 2009 | 01:44 PM
ryan8624's Avatar
Nope, drove the car to the beach, when I left it started up just fine and the radio wouldnt work. Honda wants $1070 for a head unit too.
Old Jun 1, 2009 | 01:45 PM
ReddotsS2K's Avatar
bad fuse, either under the dash or the back of the headunit.
Old Jun 1, 2009 | 01:51 PM
ryan8624's Avatar
I will check the head unit, here is a question; what are the odds of an aftermarket one working with the dashboard controls?
Old Jun 1, 2009 | 02:13 PM
ReddotsS2K's Avatar
Very slim, unless you buy a harness that fits the aftermarket stereo. Here is the site where you get the harnesses, and there should be a list of compatible headunits on there somewhere
http://www.modifry.com/
Old Jun 2, 2009 | 04:40 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
just buy a oem headunit from ebay... theyre like $50-100... problem solved... **** that $1000... my whole system is around $1000
Old Jun 2, 2009 | 09:34 AM
rice4life's Avatar
look on s2ki.com classify, you can get an oem one for less than $100.
that's crazy, $1000 for a head unit that doesn't even play MP3.
Old Jun 2, 2009 | 10:15 AM
S2KILLA's Avatar
is there an echo in here???
Old Jun 2, 2009 | 12:44 PM
user 996328629's Avatar
I just have the exact same thing happen to me. Except it happend while I had my alpine in.
I puit the stock in, and just the red light blinks.
No fuses in my HU or anything are blown. Not under dash, no where.
I HAVE NO CLUE!
Old Jun 3, 2009 | 04:51 AM
S2KILLA's Avatar
crappy oem radios are the problem... solution- aftermarket HU with modifry controls...
Old Jun 3, 2009 | 05:57 AM
I had a alpine with modifry installed when my unit did not turn on. After checking everything twice, I took out the dci and out it back to stock, my oem unit worked perfect previously and now just the red dot blinks. Whatever is causing this is not the units.......
Old Jun 3, 2009 | 08:56 AM
White Smoke's Avatar
i my honda
Global Mod
Bust out a volt meter and check for constant power and acc power. My $$ is still on the fuse.
Old Jun 3, 2009 | 10:01 AM
Some reason my voltmeter kept reading 0, no matter the setting. I gave up when it got dark. I checked every fuse, and replaced them
There is no fuse in the stock head unit, but on my alpine i replaced it also.
Old Jun 3, 2009 | 02:28 PM
Mik's Avatar
Mik
If you put in an aftermarket radio, get one that has a remote control. There is a device built you can find at http://www.pac-audio.com/swixprogram...rogramming.asp
It allows you to use the buttons on the left of the steering wheel. I use it with an Eclipse head unit and it works fine.
Mik
Old Jun 3, 2009 | 06:21 PM
turned out to be the power acc fuse for the both of us. Not really sure why that blew though!
Old Jun 5, 2009 | 06:39 AM
Stingraybeverly's Avatar
New User
I have an acura 2003 TL and the radio stopped working one day. The radio will eject CD's but not power on. There is no CODE display. I check the fuse in the passager side door and was fine...I even swapped it with another one and still nothing. Where did you find this acc fuse?
Old Jun 8, 2009 | 07:02 AM
i my honda
Global Mod
Stingraybeverly, you might wanna try the TL forums. The fuse is probably located somewhere on the driver side kick area.
RLS_Ody
Audio / Security / Video
18
Oct 24, 2019 12:54 PM
Mecca8383
Nov 25, 2017 02:46 PM
2Accords
Aug 30, 2011 04:19 PM
walkergirl
Jul 9, 2011 07:43 AM
Jpstw
Honda Civic (2001 - 2005)
Oct 11, 2006 02:53 PM
