Honda S2000 Honda S2000
Question about soft top
Old Feb 24, 2010 | 05:50 PM
trepteg's Avatar
Default Question about soft top
is it normal that my top didn't open more than that ?
sorry if it's a newb question .. i bought it salvaged and I rebuild it myself , and no one in my town have a s2k .. so I can't look on the others s2k
so is it normal ? THANKS !
Old Feb 24, 2010 | 05:55 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Question about soft top
It should go down lower than that, I had an issue with mine after not using it for awhile where it didn't go all the way down (similar to that) Keep raising it all the way and lowering it, it'll go back in.
Old Feb 24, 2010 | 06:04 PM
trepteg's Avatar
okk so I only need to make it work more often and it should go lower than that ??
Old Feb 25, 2010 | 05:04 AM
camoy's Avatar
No you should not just put it up and down more till it goes down correctly. The issue you have is the elastic bands that pull the second support bar into place as the top lowers has worn. Once this happens the bar does not quite get into place and causes the top to sit in the position you have shown. If you continue to put the top up and down you will cause the top to wear holes right above your head. You have two options either go to honda and buy replacement straps and have them install or you install (note installing yourself is a some what scary project as you will need to drill out the rivets holding in the old straps in close proximity to the soft top itself. Second option go to Modifry and get the aftermarket straps and install them here is the link also in the link is a better example of why this happens
http://www.modifry.com/products/ctf/details.htm
I used the Modifry straps as it was cheaper the install was less risky no drilling.
Either way you choose it will fix your problem, good luck.
Old Feb 25, 2010 | 09:38 AM
theineffable's Avatar
do the straps have to be elastic? what happens if one just used nylon straps in places of elastic bands?
Old Feb 25, 2010 | 10:31 AM
honeybadger's Avatar
be careful, it looks like you have a stuck bar - don't try to force it all the way down or you might rip it!
Old Feb 25, 2010 | 10:45 AM
camoy's Avatar
Yes they have to be elastic, they pull the two bars in the top together as the top is lowered. If you use nylon there is no tension there and for all purposes might as well not be there.
Old Feb 25, 2010 | 01:19 PM
Eh, worked fine for me and haven't had an issue since *knock on wood* I believed it to be more related to running with the hardtop for several months, then taking it off and using it. The frame obviously had not moved much while the top was on.
Moved it up and down twice and then it was fine from then on.
Old Feb 25, 2010 | 01:38 PM
JDogg's Avatar
if you dont want to replace the elastic, when the top is about 1/2 way down, you can push the 2nd bar down so that it goes under the latches, then lower the top the rest of the way . i had to do this for a couple of weeks till i got around to replacing the elastic
Old Feb 26, 2010 | 04:28 AM
White Smoke's Avatar
i my honda
Global Mod
It's the elastic bands! They caused a tear in my top when it was cold out not all that long after I bought my S! Do what J'dogg suggested and push the bar down as the top goes back over your head.
Old Feb 26, 2010 | 04:35 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
^^^ what jdogg and white suggested... theres a bar that can pivot in 2 directions when folding... if the bar pivots one way the top will go down correctly but if it goes the other way the outcome will look like your picture... and this is ultimately caused by worn bands...
Old Feb 26, 2010 | 02:48 PM
backstrap1's Avatar
Lol....I got a problem I didnt even know I had.
Mine looks the same....Seeing as I just bought my 02 And had never even seen one. I thought this was normal.
Old Feb 26, 2010 | 09:17 PM
Zaakro's Avatar
I not only will causes holes it can also ultimately break the latches and push it thru the top.
it has happen to me
Old Mar 1, 2010 | 08:25 PM
fivespeedintegra's Avatar
Came in here to say that I had the same problem. Ordered the modifry kit on Friday afternoon. Got an email that they shipped Saturday. They arrived in the mail today.
The whole process took MAYBE 25 minutes, and a solid 20 minutes of that was completing the first side. The other side was eaaaaaasy after that. Straps are nice and tight and pull the bar back great!
The old straps had no elasticity left. After cutting them and trying to pull to stretch them, they moved maybe 1/2 inch.
to modifry and their easy, inexpensive fix.
Old Mar 2, 2010 | 01:42 PM
backstrap1's Avatar
Mine does fine now that I know the trick...LOL And all it takes is a light flip of the bar when it starts to go ower your head. As the top goes back the bar wants to stay foreward....just flick it back (about an inch is all) and it does the rest by itself
Old Mar 2, 2010 | 03:04 PM
HOLLA!'s Avatar
Mine isn't going down all the way either. I've had it since December and was pretty sure there was an issue going on somewhere, and now this thread confirms it. Looks like I'll be getting my first warranty repair next week.
Old Mar 2, 2010 | 03:10 PM
Zaakro's Avatar
its a TSB just to let you know
http://www.s2ki.com/stor/library/TSB/A02-065/index.htm
Old Mar 2, 2010 | 08:00 PM
HOLLA!'s Avatar
Thanks, good to know, should make getting this fixed very easy. I'm so happy I saw this before it ripped the top! I thought it was possibly normal because my Miata's top never went all the way down either.
Old Mar 11, 2010 | 04:52 AM
i my honda
Global Mod
Service Bulletin
Old Mar 11, 2010 | 07:48 AM
2poor2mod's Avatar
thats not it at all.
Originally Posted by White Smoke
I found some info to add to the thread...
Old Mar 11, 2010 | 08:47 AM
camoy's Avatar
The service bulletin is correct however
Old Mar 11, 2010 | 11:28 AM
i my honda
Global Mod
Yeah it was the wrong pic...
Old Mar 22, 2010 | 07:54 PM
DirtyS2K's Avatar
Is this common after time or is this a Lemon type thing? Like random times this happens or wear and tear?
Old Mar 22, 2010 | 10:22 PM
vsm_EJ6's Avatar
Its elastic straps. They wear out.. and need to be replaced. Similar to what your mothers camel toe does to the elastic straps on her sweatpants.
Old Mar 23, 2010 | 06:17 AM
DirtyS2K's Avatar
Yeah, she goes through those sweat pants every month! Thanks for making it so simple to understand!!!!
HRD
Suspension & Brakes
Jun 5, 2007 07:24 PM
kihun_cha
Honda Motorcycles
Jul 14, 2006 09:42 AM
