Honda S2000 Honda S2000
is this the plug for the radiator switch???
Old Mar 21, 2010 | 02:33 PM
c-rex23's Avatar
Default is this the plug for the radiator switch???
i realized my fans were not turning on so i saw this plug loose and it does not seem to fit where the fan switch would go. I am using a 2004 radiator on my ap1 can this be the reason because people told me everything from 00-05 is interchangeable on the radiator and the switches for the fan motor fitted but not this one.
Old Mar 22, 2010 | 12:14 AM
s2kdre's Avatar
Default Re: is this the plug for the radiator switch???
Yes it is.
Old Mar 22, 2010 | 07:43 AM
camoy's Avatar
That is strange that plug should plug into the fan switch without any problems. This is true of not only AP1 to AP2 but more than just the S2000 use the same switch sensor, in fact a Mugen fan switch works for the following cars
Civic (1992-1995)
Civic (1996-2000)
Civic (2001-2005) Si
Del Sol (1993-1997)
RSX Type S (02-04)
S2000 (2000-2003)
S2000 (2004-2008) 2004-2005 Only
TSX (2004-2008)
Integra (1994-2001)
RSX Base (02-07)
RSX Type S (05-07)
There is a difference between the 06+ fan switches as they changed the size of the threaded side of the sensor but the plug should still be the same. That is why the list above states the 2004-2005 only. It is a little tricky to hook up since you are doing it by feel only and the key way is not very defined. Give it a try again and make sure it is engaging all the way. If it does not go on maybe the connector end of the switch is damaged. If that is the case do you still have your original setup, if you do just take the orginal fan switch and install it into the AP2 setup. Now if you do this and find that your AP1 switch does not fit then you were not sold a 05-05 AP2 radiator, like I said above they have different sized switches. Also do you have a real temp gauge to tell the acutal temperature? As the fans don't come on until about 200ish, so maybe the temp outside is cool enough that the fans are not needing to come on.
I remember you asking about the AP2 radiator setup working in an AP1 and I told you that it did. And from all that I have seen and worked on it should. I have worked on other AP1 S2000 and installed after market radiators and fans so this should work.
Old Mar 22, 2010 | 10:27 AM
c-rex23's Avatar
this is the radiator i have on now and the fan switch is on the bottom right the lil broze piece thats sticking out. My old radiator was thrown out so im mad and also can i get that piece from the dealer since im tr]ying to make it fit but its not working
Old Mar 22, 2010 | 12:32 PM
camoy's Avatar
Yes you can get it from the dealer here is the part number as listed with Honda
37760-P00-004
It should come with a new rubber o-ring as it is listed this way in the parts manual. But in case it doesn't here is the O-ring part number
91307-PN3-000
joelro28
Feb 22, 2014 12:43 PM
8OOSTED
Nov 6, 2010 10:28 AM
fast22civic22
May 31, 2007 09:34 AM
hondacivic984dr
Mar 21, 2007 04:57 PM
ELAMINT5
Mar 5, 2005 10:43 AM
